MK2 owners, easy help please!
Right, for those of you who have a 1987-1990 MK2, if you can take one minute to look at the following wires and tell me the colours i'll owe you a pint..
You have two plugs in the front of the thermostat housing, just behind the radiator fan motor. Just under the distributor. One plug is blue? The other i think is dark brown? Well i need to know the colours of the wires to each (some will be stripey, like blue/black, black/yellow, etc/etc).
Also, just behind the cam cover in the head, above the left two spark plugs, there are two sensors in the head casting. I believe one sensor is blue, possibly with a plain blue wire? The other, may be black? Or brown? With a yellow wire? I've long forgotten.
Modifying my car a lot over the years, now running a 6n2/9n engine and i hastily ripped the wiring all out recently to re-do it all, some were unconnected (one oil sensor which probably wasn't working anyway, one coolant sensor which was). Now i don't know what goes where, i've had a search here and gooog, the Haynes is loosing me at the moment because i have other wires to sort out as well (currently trying to sort out the screenwash motor, which is also from a later car).
Oh, i'm fully colourblind btw, but pics still welcome if it helps.. cheers.
  • Views 975
oil pressure sensors are i believe blue and yellow solid wires bud.
thermo housing plugs were red on the left and black on the right on mine
black plug has a blue wire and what looks to be a yellowish wire going to it, red has a black and another i cant see.
(zoomed in on an old pic of my 90' 16v so had to tell)
Edited by erixtar1992
Well Nigel8021 came over to help yesterday (cheers Nigel!), the info he had suggested we got the oil pressures and temp guage sorted, but it seems the two other wires for the other temp sensor aren't needed. The blue oil pressure is blue/black and other plain yellow (i only use one, the other is earthed until i tap the head for another sensor). Another blue i had was for the alternator. Two other wires were the washer motor, though i could only get it to do the front screen for some reason.
Anyway, he was able to tell me which MK2 wires go to which wires on the later 4-pin plug, which gets my temperature guage working. One of them was lilac, a colour i can't see at all, just looks like another blue one to me. The sensor i have is almost certainly a green one though.. from a Lupo with the D-shaped plug (was running a 6n one previously, which i'd got the guage working on eventually, but i seem to have binned it since cutting all the extended wiring off).
Whilst we determined what wires went to the second temperature sensor, we couldn't be sure what it's for! They provide info to the SSA system on cars equipped with it, according to the info Nigel had. Mine wasn't equipped with it though, most MK2's aren't yet they all have both sensors, so it must do something else. So i'll probably put the other two wires to it on the other two pins anyway, now i know which wires are pairs, even though they're for the ECU on later cars (possibly something to do with the LED on the temp guage).
