6N2 Windows Not Working
I brought the car and on the way home i used the electric window switch and they just about went down then up a few days later i tried and niether will not move
what are somethings i should check or do, are there any tests i can do (2001 Polo SE)
Update: switch on passengers side works
Edited by itzvizionzx
  • Replies 12
  • Views 1.5k
  • You need to ring or just go in
  • You may try to refurbish the switches. See here: http://www.matt-thornton.net/blog/vw-polo-gti-6n2-electric-window-switches-refurbishment I find it easier to remove the door card on the driver's si
Switches are very common for corrosion inside and stop working and also window regulators fail.
I wouldn't buy second hand switches as they could have same problem a month down the line, they're £17 each brand new from VW and the cheaper of the two so I would try them first
switch on passengers works so looks like it was the switch or maybe bad wires how do you get the switch from vw is there somewhere on line or do you have to phone
See here:
I find it easier to remove the door card on the driver's side first and then pop out the switch console to get access to the switches.
See here for removal of door card:
http://www.tigerstyle.co.uk/phpBB3/viewtopic.php?f=10&t=32888
There is one other thing you should check too (do this first). Open driver's side door. There is a ribbed rubber boot that carries the wires from the door to the car body. Start at the door side and pull the ribbed rubber boot back. This will expose the wires. Check to see if any are frayed or snapped. Very common in 6n2.
If that is all ok, then whip the door card off and check and refurbish or replace the switches.
PoloD.
Edited by PoloD
Check the regulators by putting the key in the door, and holding it over to the un-lock side.
If both windows open on the full closure, you know the switches are at fault.
Ben
I would suggest doing this from the passenger side (in case the wiring the driver's side door shut) is compromised.
PoloD.
Assuming the drivers door has a key lock on it. Rox's one doesn't.
Standard 6n2s have a key operated lock on both the front driver and passenger side.
Of course, if this has been replaced or 'de-locked', then there won't be one!
PoloD.
Ah I didn't know that.
This one's been de-locked on the passenger side then. It's still got a lock on drivers door as it doesn't have remote central.
Ben
Thanks so much tried this didn't think anything would happen, windows worked perfectley on both sides, saved me alot of time and effort :D
See here:
PoloD.
Will follow your guide thanks for simplifying the process and probrably saving me $$$ :tongue: .
Thanks for the advice already in this thread - though holding the key in the unlock position doesn't open both my windows.
Does that mean it's definitely the regulators?
How much am I looking at to get that replaced?
  • 5 months later...
When replacing the driver side switches, do you have to replace the entire thing as a module, or does each switch come out separately?
I've got an issue where both windows work, but the driver's side switch to control the passenger window only works to take the window Up, and not down. All the other switches work. Just one switch, one window, one direction. How annoying.
Also, does anyone have the Part Code for the switch so I know what to ask for?
