porsche teledials
  • Views 2k
944 hubs have studs fitted of the right length so just need bolts like this http://www.ebay.co.uk/itm/x20-M14-x-1-5-Alloy-Wheel-Nuts-For-Porsche-911-912-924-928-944-968-BLACK-/161284844167?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&hash=item258d536a87#ht_2326wt_1311
I would have expected that hub adapters would have studs already fitted, in which case the real question is, what thread and pitch are on the adapters ?
If the hub adapter doesn't have studs, then you need to check the thread / pitch for the threads in the hub and then measure how long you need the bolts to be.
they don't have studs i need bolts i know i need m14x1.5 but i just don't know the degree of the bolt head seating to the wheel ??
Try this thread.......... Porsche wheel nut & bolt fitments were pretty much the same all the way up to the 993............... don't ask me anything about 996 and newer though.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946
There's a good picture in there and details of the radius size
........... and see this thread for more info on radius and taper, in case you need additional explanation. Porsches do have 19mm heads on the bolts
http://www.edition38.com/forums/index.php?showtopic=365732
Edited by 937carrera
Looks promising :smile:
