Spring poundage
What spring poundage do you guy's usually use on your coilovers? I have some on my car right now and the springs are rock hard and it's dangerous.
Need some for polo coupe 1994 M-REG
Edited by kwijibo_coupe
offensive language removed
  • Views 1.5k
Not sure what the wheel travel / static displacement of polo's are as standard but we could make the following reasonable assumptions:
- They are sprung to give around a 1.5Hz natural frequency in bounce (this is roughly an industry standard)..
- a 6N weighs ~800kg kerb,
- Further assume a 50/50 WD
- Assume front and rear struts give a roughly 1:1 motion ratio
= 18 N/mm spring per corner
which equals 103 lb/in spring per corner
Depending on what percentage of ride height / ground clearance reduction you want with your coilovers will roughly determine how much stiffer your coilover's springs should be.
As an example, if you want to half your ground clearance from standard, you may need to double your spring rates (to prevent grounding out), so 200 lb/in springs would be required. Fitting these springs would double your ride frequency (3Hz) which I believe would give a car that feels sufficiently 'rock hard and dangerous' on normal roads as in your case.
This is all ball park figure stuff / rules of thumb so exceptions aren't necessarily bad.
I'd be interested to know if anyone has rated some actual OEM springs, and has ratings of some common 'coilover' spring optionsto compare. Do you have a stiffness value for your springs, Danny?
I don't have the stiffness value sorry mate. But thank you for this information.
Edited by Danny9689
