Coolant leak +bleed screw snapped!
Ok, so my 1983 1L bready has only had short runs all winter.
Took it on a run from Basingstoke to Winchester to clear the cobwebs/mayo.
Sprung a coolant leak on the way back. The leak is from the pipe that goes between the rad bottom and engine.
2fba71e9-5851-491b-8f81-3136ac708c74_zps
I noticed its a solid metal pipe it connects to, which is quite corroded at the end. Fixed one pin hole with solder,
but another leak remains. How do I remove the whole solid tube so I can fix it properly?
And just to make my effing day, the bleed screw snapped off in my hand. great so now I need a replacement matrix valve as I cant get the broken stub out. So 3 hours work for sod all. Meh, Can anyone please help with any of the above?
Thanks.
Broke until friday if i'm lucky too...... my week just gets better and better.
  • Replies 10
  • Views 1.5k
Just found out that the solid tube can be removed. Any advice on refitting? seals etc?
That sounds like too much bad luck for one week.
If that's the main water pipe at the back of the block there's a small diamond shaped gasket where the pipe attaches to the block by two bolts.
If it's all clean (no corrosion that end) the gasket is all that is needed.
My last headset kit contained one.
It's VAG part 052121091A if you want to order it from a dealer.
When was the anti-freeze last changed? It has corrosion resistant properties
that are useful all year round.
Coolant was seriously crap when i got it, several flushes this last year.
Where can I get a new tap from though?
Thanks for advice.
Edited by funkster
Should be. Pretty sure it's same block but different crank for 59mm stroke of 1043cc rather than 72mm of 1272cc.
Send an email to VW heritage?
Only variation I know of is more inlet/outlet taps for inlet manifold heating and auto-choke.
Edited by dvderlm
Thanks for advice.
When you say tap do you mean new bleed screw?
Maybe a scrapyard VW. Think Golf Mk2 1.6 had same white bleed screw.
Possibly replacement heater matrix - if it's full of old rusty bits not a bad idea anyway.
Thanks, emailed vw heritage, not replied yet. Seems a bit sleepy there lol
Well I got the pipe off, cleaned and de-rusted as best i could. copious amounts of solder in various places and painted to seal it. Just to try to get things moving forward.
Making a gasket out of cereal packet old school style lol. Should I use a selant as well, if so what can I use. Would silicone work? Even exhaust paste? All I have in the tool box atm...
Try not to laugh too hard... Cheers
Silicone :)
Anyone got a bleed screw spare please?
