mk2f flushed doors
HI,
I've got a set of doors from my coupe project, that have had the door handle sections all flushed off.
One door has some rust on dueto being stored in the cellar but can easily be removed from prep work. its only surface rust from taking a look at it carefully.
I'm looking for £60 for the two.
post-920267-0-41833700-1437375835_thumb.post-920267-0-01821400-1437375850_thumb.
Edited by NickBraddock
  • Views 691
Just curious, what would you use handle-less doors for? O.o
You'd use solenoids to open your doors rather than a handle
indeed or if you have a clifford to toad alarm, these can be programmed to open the doors using the solenoids instead of a button say under the wing mirror
do you have some close up pictures of the areas that have been flushed?
i'll get them this weekend, these were originally on a G40 that was quite some car in 2002 lol
