Too many holes in fuel tank.
Anybody like to give odds on how successful i'll be patching up this rusty old shitter?
Not sure what i'm gonna use yet, but i'm borassic lint (for a change) so I'm not gonna fork out 70 squid for a new one, dats for dam sure!
No 1 is where i think it's leaking
No 2 is where it's gonna start leaking if I don't do something, probably splodge on some hammerite :-o
By the way, all those on here who've said getting the tank out of a mk3 was a flippin' shite job were spot on! :angry:
Edited by Chuck Yoghurt
  • Replies 26
  • Views 3.5k
get it down to bare metal and start from there. I used epoxy resin to seal the holes in mine, it worked very well. give it a coat of hammerite afterwards and job done. then look out for a new one down the scrapyard, as ~£10 < £70 ;)
As you can see, i'm cleaning the rust off. Only trouble is, the hole is not revealing itself. How frustrating! :-(
What if I filled it up with water? I could let it drain and dry out again for a few days, and the weather here is nice at the moment!
What do you think??
yer when i did mine i washed it thoroughly several times so tht i had NO petrol in the tank and then get a company to fill it with compressed gas to see if its air tight (as youknow it isent to find where the hole is...)
have you put wate rin it to find the hole? also abit of quiksteel around the whole area will seal it and theres no chance of you blowing it up doing it with taht stuff neither lol
GOOD LUCK
there's a product called por15 car tank repair
http://www.frost.co.uk/result_search.asp?k...CFQRmEAod0il0aw
when you've patched the outside, this would create a second coat inside the tank, filling the pinholes from inside
peace and good luck
pabs
Don't even think about trying to weld it. My brother did that on a tank a few years back - he washed the tank out loads of times before he welded it and it still blew up!
people say either fill it right to the top with petrol or right to the top with water. as its out the car, I'd go with the water!
ARALDITE UBER ALLES! :D
Now for the hammerite!
Is that pikey enough for you, Skatty?
Thanks for your suggestions guys, I used Araldite cos I already had some in the shed! :retard:
PS for all you guys with non-leaky gas tanks, I advise you to clean all the dirt and shit out from around the filler neck! :thumbsup:
That'll do nicely, mine was done pretty much like that over a year ago, still fine :)
There is a product called leak fix, which is an epoxy suitable for exactly this job. Its very good. The other thing I would advise you to use is "petro patch". Its got a bandage thing in it that you coat with this weird blue stuff, which after you leave it for a while turns rock hard and petrol proof. My old tank was much worse than that and it leaked no more after I used those two.
Tetrosyl LeakFix is Magic. Works on gearbox casings without draining too!
Looks like new! You jealous??
Of course, I haven't actually filled it with fuel yet ! :-D
(Or wrestled it back into the car, either!!!!)
I know its sorted now, but would fiberglass work? Whack on a few layers of matting with a liberal coat of resin
I'd have thought so. Just needed a cheap solution for now. I still had to fork out £6 for the paint though, hmph.
Once this is back in I still need to buy a front shocker, maybe a top mount and certainly a driveshaft to replace the one I stripped the thread off in an act of incompetence.
Cheapest driveshaft I found is £25 off Stevens VW near Chelmsford. Anybody live near Cambridge and wanna sell me one cheaper than that?
Only then can I run the gauntlet of MOT hell.
Did I mention i'm potless?
Must be that time for polo's as my tank also leaking, yes that part of the neck that goes under wheel arch. I bloody always hose round there as well!
Any how just as broke but went for the new tank (GSF done it for £64+VAT) I've opt'd for undersealing the new (pride of place on kitchen floor at mo) tank. If old one repairable will do and then have a spare should I get another polo at some point :)
Was having a quick read on how to get tank out i.e:
remove fuel pump relay from ECU
crank engine over till stops running to reduce pressure in the injectors
dissconect sender unit for fuel gauge
remove rear wheel, lift exhauts from hangers, remove hand brake cable.
Now all this seems fine as have been under the Polo to see what's involved, but it also says to unbolt the right hand axle beam mounting?
Now I cann't see why this needs to be done to get at the tank, as the mount is behind the neck of the tank and not in front?
So did you remove it or leave it in place?
Any tips from any one
Edited by Markh73
I see you found GSF then :D There is a couple of mk3's at a scrap Yard in Rampton. Went there for bits on my mk4 but there was only mk3's. Should be pretty cheap there think they let you dismantle shit yourself too. My girlfriends sisters old genesis should be sittin down there still! Walk off with it in your pocket they will never know! :lol: :lol:
Nice one, mate. I'll get off down rampton tomorrow and have a looky.
As for you, Markh73, I did remove the beam mounting because Haynes BOL says so, and I am a helpless automaton.
If you can do it without then fair play, because otherwise you'll need to disconnect the brake pipe, buy more brake fluid and bleed the frigging brakes, just like Uncle Chuck.
If you're unlucky, your car will idle shite afterwards. Just like Uncle Chuck.
I'm impressed, very pikey, but very good job you've done of it too mate. I'm sure we can find a position for you here at PikeyTech...
I made a great job of lowering my car this weekend - couldnt get the assembly off the top of the rear struts to fit to the new shocks, and couldnt ge the old springs back on without a lot of hassle, SO its currently running one corner slammed to the death on a knackered shock and no spring hahaha...
Still a good few inches of arch clearance though!
SkAtTy!!!! Just you watch it, mate!!!! :lol:
I havnt actually seen your car yet stick up some pics of it. Il keep an eye out for you. I take it it is currently off the road atm tho?
Right now it looks like this;
I was planning to spend the summer giving it a cleaner look (no trim, stripes or wanky 'fox' logo), but instead I'm working just to get it through the MOT! :-( (We are off the road just now, yeah)
If SteveO ever sends me the welcome pack it'll have the club polo sticker on it too, not sure where yet.
Let's have a look at yours.... (ooer) :lol:
repairing petrol tanks is a no win situation, the time and effort to repair, and it will leak through, i assure you
the worst part of it is removing and then fitting
then it lasts a few weeks, leaks again and you have to do the job again, and buy a new tank...
£60 for a new tank is nothing!
You buying, then? :lol:
If it lasts long enough to get through the MOT it's mission accomplished as far as I'm concerned, Mr Knight! :p
Well as I said I fixed mine over a year ago like this. It hasn't leaked since... so I won :lol::-p Touch wood :paranoid:
I've done reapirs in the past, fibreglass works well, but if you're going to the bother of taking a tank off and putting it back on, do a replacement everytime. You can get a pattern one for £30-40.
