Fuel tank leaking
After my £90 MOT on my mk2 I thought everything was too good to be true and sure enough after filling the car to the brim as a treat for it petrol has started to leak out of the tank. (It took £32 to fill the tank) :crybaby:
I'm assuming that the leak is high up in the tank as the filler neck is wet with fuel and that hopefully when I run it down and return to putting in £10 every few days then the leak will abate.
What I need to know is
a) how dangerous this leak is and
b) how much can I expect to pay someone to fit a new tank as £62.50 exVAT from GSF. (I don't have the facilities to fit a new one myself)
  • Views 1k
well i would want to smoke near it lets put it like that mate, petrol leaking is not a good thing just think of what could happen it probly wont but it could. mine didnt cause to many problems just got worse an i coulnt even get a tenner in it without it leaking.
if they know what there are doing it can be done in half hour me an my mate did mine in just over that time with instructions off here.
it is quite straight forward just a bit fidderly
Edited by wozzapolo1.3
