corroding fuel filler neck/fuel tank
Hello does anyone know if you can get a replacement fuel filler neck for a mk3 coupe or do I need a whole new fuel tank?
Have been noticing recently a s rong smell of petrol around the car and actually getting in the car :? Had a little look underneath the car and it seems to be the fuel filler neck near the bottom of the wheel arch (loads of crap has collected behind the filler neck and wheel arch and thats where the smell is the strongest)
Expensive repair or not?
  • Replies 13
  • Views 2.2k
you need a whole tank, they're all one piece. Cost about £55 for a pattern part (i.e. not genuine VW) supplied. Fitting isn't too hard really but with a pattern part you might need to bend the neck slightly to get it into the correct position.
I thought as much :sad: Not really a job i can do myself either is it?
Yeah you can do it yourself mate no worries ...
Iff your thinkinga bout keeping your car for a while itl be the only thing that will need changing apart from obvious bitts and pieces ..
I found the ones form GSF fitted fine :-)
Is it not gonna be a bitch to do without getting it on a ramp? Cant see myself being able to get the fuel tank underneath the car with it only supported on axle stands, surely thats not high enough?...
anyone?
Up on axle stands @ the back is fine
swapped my gf's fuel tank. the guy who i bought it from thought it would take ages - so flogged the car for £50.
bought a tank from Rn1988 on ere. fitted in in 1hr!
tools:
sockets - with extensions.
axle stands - (the rear axle has to come off to get the tank out)
screw drivers - (pipe fittings)
just takes patience, i did it on my own aswell.
tools:
Dunno if this is a dumb question but if the rear axle has to come off where do you put the axle stands?
Edited by aroncmc22
Again... anyone??
Jacking point at the rear of the sill - carefully.
You may be able to get away with dropping one side of the rear beam, á la Haynes, but I tend to drop the whole thing, it just means you have to have someone there to do and undo the bolts while you bench press it up and down.
If you're using a pattern tank, paint it well to stop it rusting away again, then underseal it up when it's on.
The first time I did one, it took me an afternoon.
Thanks mate, dont sound too difficult really. My brother (who works at gsf) said something about having to cut something of the old one to re-use... ring any bells?
Dont cut anything just drop the rear beam take the old tank out under seal the new tank if you dont under seal it you might be replacing it in a years time fit the new tank bolt the axle back on job done. The jobs not that bad
The plate with the lift pump (where fitted) and sender unscrews from under the rear seat.
