Replacing locks - Help needed!!!
Trying to fix my central locking at moment, seem as tho the paddle was bent
what i need is to take the paddle from the new lock
and fit it to my old barrel so my key still works
I am just now sure on hot to remove the barrel from the new lock and fit it 2 my original.
Can anyone help?
pretty sure it can be done but does anyone know how????
The replacement handle
The broken paddle
Edited by scoopsy
  • Views 2.3k
Can anyone help me out guys???
Right,
Take the spring off the barrel. This will release the barrel and paddle from the handle.
Hold the barrel assembly vertically with the barrel at the bottom and the paddle at the top.
Trace down to the base of the paddle.
There is a collar holding the paddle into the barrel.
Slide C shaped collar off (ie push horizontally - you may need to push down at the same time to overcome the internal barrel spring)
Be prepared as the internal assembly of the barrel will come shooting out. (there's a spring inside)
Remember what order the bits come out in.
Replace the paddle and the castle spacer also.
Reassemble.
May be an idea to grease the lock while it is in bits.
Refit to car.
Smile.
PoloD.
Edited by PoloD
PoloD
Much appreciated bud
Shall give it a try 2moro and let u no how it goes
Thanks again
