Project Muppet - 1980 Golf N, Pastel Green
ooops, i forgot to come round :lol: i even forgot saying i was going to come round :lol:
I`ll deffo call round tomorrow 8-) give me a text to remind me :lol:
Just got to go round to my mates to give her CAR a service first, damn corsa too :roll:
  • Replies 111
  • Views 21.9k
removed both exhaust systems off the car today and got the stainless steel mani on the muppet, and ordered my silver top competition fuel pump/filter king reg today so they should be here along with the carbs, woohoo! didnt bother getting any pics today as i was covered in cv grease haha
Tomorrow only got a few jobs to do, wire up harness pre-tensioners and re-fit speaker and door cards, drain oil and re-fill, fit stainless centre pipe and finish removing the g60s as I've sold them, just replacing them with vwIIs for the time being
just a wee note of bits I've still got to get
Pre MOT
Backbox
22mm master cylinder - GSF 65276
Bushing Kit - GSF 71709
Brake Fluid - GSF 98101
Stuff still to get
Wishbones x 2
Polybush - Rear beam x 4
Polybush - Wishbone
Polybush - Front ARB
Polybush - Engine/Gearbox Mount
Polybush - Engine/Gearbox Insert
Strut Brace - Front Upper
Strut Brace - Front Lower
Strut Braece - Rear
Seats
Rear Disc Shopping Conversion -
Golf Mk4 Calipers
Mk2 Rear Discs x 2 - GSF60340 - 15.95
Mk2 Rear Pads Pagid ( 1 Set ) - GSF64601A - 14.90
Mk2 Rocco 16v HB Cable x 2 - GSF73132 - 9.50
Mk2 Rear Wheel Bearings x 2 - GSF41311K - 5.95
Mk4 Caliper Hoses from TSR
Edited by grungeisdead
YAY for CV grease :roll:
Oh dude, i was going to text you, lmao i saw some noob on a bike get smashed by a bus on my way home from yours :shock::lol:
On that bit where you have to come off PPW to then go under and get back on so you can join the m60
Major FAIL - ooops! :lol:
LOL what a fool, bus 1 - biker 0
should have been a schhool bus for full on comedy effect, 30 scarred screaming children
Yeah and 1 normally quiet, sick individual sniggering whilst taking pics :lol:
got a few things done at the weekend, harnesses are all wired up and door cards all fitted.
removed the g60 brakes and packaged them all up and put my 239mm setup back on, only to then win a 270mm tsr conversion on ebay :lol: so they will be coming off again, but its got a set of new pads,braided hoses and calipers, i dont need the calipers so ill make up a VWII G40 239mm setup for sale complete with grooved/drilled discs and new pads
also got 2 mk2 rear disc stub axles and caliper carriers ready for some mk4 ally calipers :-D
so i still need the following things for that
Golf Mk4 Calipers
was on a bit of a spending spree :lol: bagged this for 15 quid, debadged twin spot grille, I'm not a fan of quad lights on mk1s but cant beat that for a bit of cheapness
The Carbs arrived in the post today, so i had a nosey around to see how complete they were and what i still needed to get, trial fitted them on a spare head and found out i need longer manifold studs 50mm is too small, measured it up and i need 80mm studs so will have a gander for them.
Also needed to get a 2-1 adaptor block for the throttle cables and a 3 way t-peice adaptor for the fuel line to the carbs, got these for 14 quid through eurocarb.
anyway some pictures of the carbs, trial fitted to the spare head and car to check out any fitment issues and clearance issues especially around the MC, its tight but perfectly do-able. Ill be fitting a 22mm master cylinder I've got in the house so ill route the brake pipes accordingly.
I've decided to mount the fuel pump and reg on the scuttle panel next to the coil, it'll just make for easing routing than having it go aruond the front. Does anyway know what i do with the mechanical fuel pump on the block? do i just leave it disconnected?
trial fitting on spare head
inlet manifold
not sure of make, holes are correctly ported for the inlet holes on the head however it could seriously do with some polishing internally
a couple of randoms
them trial fitted on the car
MC clearance, good enough :D
sorry for loads of pics but I'm sure someone out there will apprieciate them :D
oh and i still need to pick up a backbox, bushing kit and brake fluid before i get anywhere!
Is looking good bet that will shift some once it some together poor car wont know whats it it :badgrin:
mm sexual carbs! and good to see you got your pumps and filters mate :thumbsup:
Pics are good 8-)
Take a while to load :lol: but still gooood! :nod:
I'm jelous of your carbalicious-ness (a word :-p:lol: ) :cry:
project muppet - eating virtual memory across the globe :lol:
Nice! DCOE's?Where did you get your facet pump and filter king from? Need to order me some.
woohoo happy days, fair few parts came today to add to the stock pile
filter king pressure reg & and facet competition silver top pump kit
270mm discs & new pads
VWII Calipers with new seals and sliders, painted red now, painted the tips of the braided hoses too (fitted with tsr/autocavan 270mm spacer)
rear stub axles for disc brakes, cleaned up and painted
rear caliper carriers
tsr gear linkage and short shift for the relay shaft and teflon bushings. will strap a weight to the shift rod for a weighted throw
Got on the blower to GSF and got the following bits on my trade account because i spend too much money there :roll:
2 x wishbones
2 x ball joints
6 x nut/bolt/washer for above
gearbox bushing kit
passat 22.2mm master cylinder
also managed to track down some m8 x 88mm manifold studs to mount the inlet manifold.
oh and the state of my spare room at the minute! only tommys room and the bathroom remain car part free
sneak peek at the new rims, wont be on for a while and cant even pick em up till next week but stil
and the reason why i'm not doing much on the motor at the minute
WTF IS THAT THING :lol: coursework? :lol:
Its a lego computer controlled robot :D
nice bit of kit
Edited by poyzon
DUDE!!! you HAVE to let me play with R2DT and lego mans demented sick gay love child next time I'm there :shock: :-D
What does it do?
aye it is, i changed the firmware so i can program it in java, built an artificial neural network for its brains :lol:
edit for walsh, it just follows a line and has collision detection thru the bumpers but all the inputs are propagated thru a multi layer artificial neural network which is just a tech way of programming just to show evidence of an AI technique adapted to a lego robot
edit as i didnt type quick enough and the answer was posted :lol:
Edited by POLOMON
I have no idea what the hell you just said, but i still want to play with it mwaaahahaha it sounds cool 8-)
bring 6aa batteries lol cos its flat as fook :thumbsup: naww I'm gonna go get some tomorrow but i have to finish more writing on my disso before I'm allowed to get tech with it again plus i have to give it back when i finish uni so I'm probalby going to have to buy one
We can train it to work on our cars :lol:
While we kick back, slap it with some computer lingo/tamachimoto suzuki elastoplast ram2000c zeebot etc stylee cable and say "get to work you dirty robot slut" 8-):nod:
i told my mate i was paintin the wheels white, well told her she painting the wheels white and this is what she thinks they are going to end up looking like
people would be like.... dyamn biatch, they be some sexy wheels
You HAVE to do them like that :shock:8-) they pimp too hard :nod:
But with a polished lip 8-)
i was going to do something like that but decided to do a tracking device using solely signal strength from a wireless sensor network, what do you study dude?
artificial intelligence and cybernetics fella :D
