Richbrook Dis-Car-Nect Immobilser
This basically goes between the battery and the battery lead in your car. You can unscrew the handle and it breaks the circuit so the car can't be started. Good for if your leaving your car in a ghetto or if the car is in storage for a long time. The fuse in the side lets enough electricity trickle through so that your radio settings and what not are left as are instead of being lost, but if you try to start the car the fuse just blows.
You will get the dis-car-nect unit, the by-pass fuse wire/holder and a spare pair of fuses. As well as the fuse thats already in it!
Can do these for £10 delivered.
  • Views 295
