B-shaw's Satin Beast
Why are AFH cams so frigging expensive :mad:
KamRacing
But i so so badly want some... haha
  • Replies 1.6k
  • Views 182.8k
dont forget the fact that i dont think thats a set!! and you have to buy the vernier pulleys too...so an extra couple of hundred on top of that plus a remap =O equals way too expensive but i still want some for my hybrid
Your doing one too? haha!
Remap wont be needed, but i bet getting the carbs set up will cost more than a re-map anyway :lol:
tbh, i think i should step away from the cams. asif 140bhp (ish) isn't enough
I'm still ringing newman to see if they do them any cheaper. If i can half the price of the catcams one i think its a done deal.
mines a mk4 hybrid running standard injection setup.
if you have any luck finding some cheaper, would you mind passing me the details along?? Id be hoping with exhaust/bmc/hybrid for 140ish also but would still like to take it further with cams...lol
Will see what newman say
Also, ill try a few of the other ones, kent cams and piper cams etc.
thought about getting a pair of cams reground?
Possibility i guess martin.
Where does that kinda thing?
Is really really feeling a set of 14x5.5 Compomotive TH's with Yoko A539 185/50's
Opinions? More so on the tyre size.
yeah, martins right, i contacted autosprint in birmingham about getting a set of afh cams reground and he quoted me around £180 for the pair, he also offered the possibility of making a set of solid inserts for the lifters and the highest lift possible reground cams for around £300, although he said i would have to send him part of the valvetrain first to see weather he can convert to solid lifter
Tyre size should be ok (i normally run 185/55x14) would of thought you'd need a wider wheel, mine are 6j
A cheaper option on the wheels may be vauxhall astra mk2 gte alloys, look very similar but with centre caps
Edited by philpheasant
I'm going to see what compomotive do, they only list 5.5 on there site.
Also, with how low i am it could cause problems.
My rears already rub with the 13's on (with standard G40 size tyres, i forget the numbers. 165/65 maybe?) when i have a bit of weight in there.
Also, offsets are custom with compos, so i could have a slightly lower offset to give it a bit more width. Not that i need to mind.
I'm liking the motorpsort theme a lot atm lol, as you will soon tell by what I'm hopefully buying in the next few weeks ;)
And that sounds a done deal Will. £180 for the pair..
However, you have completely lost me on these solid inserts? lol
I'm new to all this engine stuff really. Still learning as i go.
Also, what profiles would you advise? as thats another thing that completely looses me. the catcams website has a section to help you understand, i finished reading it more confused than at the start lmao.
ye, £180 is a very good price, go onto the autosprint website and get the guys email address, really sound guy to talk to and will help you out, he does alot of work on vauxhall redtop engines etc
afh engines have hydraulic lifters, converting to solid lifters allows for higher revs dependent on the strength of the rest of the engine and the ability of better reground cam profiles. have a read on the web about regrinding cams and solid lifters and youll come to understand in the end
Cheers :D
Done some reading, it kinda makes sense now haha.
I'll leave it to the bloke at autosprint to figure out what ill need though i think :lol:
Might have the head ported a little too tbh. Will see though :)
Whilst i was looking up reground cams... i found this...
And you think they are big cams?
Look at the size of this monster :lol:
shit ! :lol: looks like its out of a train !
bloody huggggggge cams :lol:
jack was getting his cams reground for the golf from kent cams. try them
I heard you the 1st time dom ;) haha
I think on Monday, I'm going on a massive phoning frenzy lol
haha good!
piper did that dubownerbilcos afh cams for an attractive price.
God that looks like an elegant engine drop.
I dropped my engine out today and it looked like an elephant giving birth.
lol, thats after we had done it. All tidied up about to go for a brew.
Alex picked the engine up just, sad times.
No going back now, 16v's or bust :lol:
why did you paint the starter even though you cant see it when fitted. lol
Them cams are massive.
They use them as a mould for your mums dildo :lol:
and for you butt plug?
