awesome gti modded mk1 16v golf
ADVERTISING BOTH OF THESE ON BEHALF OF MY NEIGHBOUR
PLEASE RING PAULO ON 07789 641042 FOR MORE INFO
Mk 1 Golf GTI 1.8 16V Conversion
Spec list
Engine
Complete MK 2 1.8 16V GTI KR Engine Conversion carried out by Awesome GTI inc full 16v engine loom which has been cut back to fit. Includes new ignition expander and ECU. Engine has covered around 85-90k and is from an F Reg MK 2 GTI 16V.
5 speed GTI 16V gearbox
Scirrocco 16V Driveshafts
Lightened flywheel
Black Diamond heavy duty performance clutch
Supersprint 16V exhaust manifold with all new exhaust gaskets.
Hand made exhaust with 2.5 inch centre pipe running into to a twin 3 inch DTM backbox. No CAT or silencers.
New fuel tank and filler neck complete with all new fuel and brake lines, fuel pump and filters. A new set of standard bosch injectors have also been fitted.
Magnecor performance leads
New alternator, distributor and thermostat.
BMC panel air filter inside drilled airbox.
Chrome Power Rohr pipe.
Chromed rocker cover and 16V Inlet manifold
Chromed battery and radiator cover
Mirrored film fitted to inside of bonnet
Brakes
Mk2 GTI 16V front brakes with 256mm drilled discs and fast road pads.
Standard drums on back
Suspension
AVO Coilovers front and back. Fully adjustable for height and damping. (Can go as low as 120mm)!
Wheels
7.5 x 16 Fitapaldi 5 spoke with Yokohama tyres in good condition
Body
Custom 2 tone respray in Llasa Green and Mercedes Silver towards rear. (see pics)
Complete Cabriolet Clipper body Kit
Carbon Fibre scuttle cover
3 slat de-badged grill
Green headlights
Tinted rear lenses
Personalised Number Plate
Bee Sting Aerial on roof
Interior
Full MK1 GTI green and grey striped interior.
Black Corbeau Targa Racing bucket seat on Driver's side with customer mounting bracket to fir MK Golf GTI.
280mm Momo Steering Wheel
Sparco Pedals
Motorsport gear knob
GTI White Dials
Chrome door catches, door locks and sunroof handle.
MK 1 Golf GTI Sill protectors
Electric Windows
Chequer plate floor mats
Carpeted boot
Kenwood MASK Head Unit and 6 disc CD changed fitted with 5.5 inch door mounted speakers and tweeters in the front door cards. 6x4 inch JBL speakers hidden in rear grills next to parcel shelf so cannot be seen. All new wiring installed as he old wiring was tatty. All cabling installed ready to fit your own audio into boot.
Clifford Cat 1 total closure alarm with spare fob. This means this car has remote central locking which is activated via the alarm fob. Windows can also be opened and closed via the alarm fob.
In addition to all of the above I have items which I have not yet fitted. These can be included at extra cost
Bonrath Single wiper
Pair of Bonnet Lifters
Sprinter Vented Wing
Samco Hose Kit (Blue)
Carbon Fibre Door cards and rear quarters
Zender 3 piece Spoiler
Set of standard MK 1 GTI rear lenses
Alpine Tape Head Unit + 6 Disc CD Changer
Misc. Interior items very useful for spares.
Set of 4 original 14inch GTI alloys in need of refurb.
However -
Bad points
1) Passenger Side Skirt and front wheel arch becoming detached from bodywork. This is not a big thing to repair and can be done by any body shop.
2) Couple of scratches on the bodywork but the majority of these will polish out.
3) Few Stone chips on front bumper and bonnet but again this is not anything major to repair.
4) Driver side electric window doesnt work as the cog doesnt catch on the electric window mechanism but I have converted this to manual so the window still goes up and down. The electric motor works fine and just needs reconnecting with a suitable cog.
5) The Sunroof doesn't open but I have all the metal cables, cogs and seals in order to repair this. They are all genuine VW items and will fit perfectly. All parts are still in the original packaging from VW.
These are the only bad points but believe me they are not major and as you can see from the photos should not sway your opinion of the car. I have receipts for ££££'s and loads of previous service history.
As you can see I have spent a lot of money and time on this car to get it in this condition. This is by the far one of the best MK1 Golf's out there for the money and by far one of the most distinctive you will see.
£3,500
If you are interested then call give me a ring 07789 641042
  • Views 565
