Show us ya...
A house key is a 2D cutting path. The 3rd dimension is already there in the key type - so if its a Yale key,for example (other manufacturers are available etc). And the same can be said for a VW key - there are only two types,easy to see,so you only need the 2D cut of that type. I could probably copy a front door key from this topic,accurately enough to work with persuasion,with a Dremmel.
  • Replies 103
  • Views 11.1k
To be fair Mikey- you're no mere mortal, I'd expect a man of your calibre to forge a key from a raw nugget of iron, stick bike carbs on it, and break 15 gearboxes.
The two VW keys I have sat infront of me have different depth cut outs in them.
I will give you £1 if you can do it to my house
well surely if they could see how far off real size your key was with buyin or getin a real key of what ever car u have meausurin that and comparin it to the pics they coudl work out the differace and work out the rest?
mikey if i put up a pic of a key can you make it and post it to me. If it works I will pay you.
and before anybody thinks I'm stupid enough to ask for a house key and then get it posted to my house I am not.
Edit to add - I seen a pikey break into my house in about 4 minutes when I got locked out
Edited by GiorgioGT
make it £2 and u got ure self a secured deal
CAUTION
Not to piss on peoples' parade...but did you know those displaying a full profile of your key blade can have their keys cut from just the photo!!!
You never know what kind of pikies are looking so I would blank/crop out your key blades.
Mahbs
OK people just a quick lesson on how it works using an example...
Right, to start with keys with the flat blade HUF HAA eg. 6n and later have a key code associated with the key profile.
This code is a 4 digit code which you will find on the Black key information tag that you have with your owners manual.
On this tag you will find one 4 digit number which is your key profile and indicates the physical cuts on the key. The other 4 digit number usually found under a scratch-off panel is your immobiliser/transponder code used to program your key in with the ECU immobiliser.
As the physical key code has only 4 digits and each digit is 0-9, there is a finite number of combinations, albeit a large number (10,000).
What the software does is look at the picture and infer from the visible points the most suitable of key profile that matches the photo.
The depth of the cut is standard across the flat blade keys and thus a key can easily be cut and a key code provided for future reference from a simple clear photo.
Mahbs
Edited by Polo M
Mk3 keys aren't flat- and I'd still be surprised if you could do it to the accuracy necessary for the key to actually work.
Anyone got any internet links to places that actually do this?
I can't say for sure with mk3's but for my 6n I have had one done tried and tested works fine and cut is identical to my original. I had it done from a photo as I did not get a key info tag in my owners manual from the previous owner.
You have PM Yoof.
Mahbs
Edited by Polo M
Lol i guess the chav's are getting clever these days!
Cheers for the link- like I said though I doubt it can be done from just a photo with a Mk3 key, it still remains impossible to get any accurate depth measurement from a 2D image, whilst in a profile view ;)
You may be right about my super-human abilities Yoof,but even i cant see how to modify a car key with a fuel dispensing device. And i thought an intelligent man like yourself could tell the difference between four and fifteen - if not,its little wonder you couldnt cut a key from a computer-graphed image of one,using a blank key of the same type. You'd probably just kick the front door in,like me.
  • 2 years later...
Thread resurection!!!
back on topic
mine
surely you'd need some sort of reference of size in the picture?
i.e a 50p coin (something universal) and key side by side flat on a table...
your wish is my command
i thought everyone would have a rough idea how big a key is?
And the fact that there's a key in the original picture anyway lol.
wow, that must be comfortable in the old pocket there chief.
There are a few Volkswagen key types,its easy to see which one is which just by looking at it. Mine is AH i think,which is the layered flat type. The other but less popular one for the MK2/F is HV. The latter has more pronounced ridges down the centre.
They're all the same length,uncut ones cost a tenner on ebay,so a grid print enables an accurate replication to be made from a photo via silhouette. Might as well put a stencil of your key next to your Fli sticker..
Not that steering locks are difficult to get around. It just cracks me up how people tell the world on here what expensive stuff they've put into their cars,then put their plates up,then put their key patterns up. Smooth.
True, i use the logic mines a J reg shitter, anything of value does not live in there. Really surprise that no-one tried robbing it yet, then again they're not gonna get far w/o a battery or a steering wheel
you'd be surprised at the creativity of mancs finest crims haha
Mine's broken off now so haven't got a picture, but I had a scale model made of the fimo shit of a polo mint. Was so realistic one of my mate tried to chew it off my keys. He is retarded though
A mate of mine had 3 crossers chained together inside his house, they tried picking up all 3, carried them across the road then ditched them at a kissing gate :lol:
but yea, on my keys for car i have a russian navy dogtag and some random one i stole from a jacket in TK MAXX thinking ' OMG THATS SO KEWL'. Mainly for weight, i hate having light things in my pockets and then not being sure if they're actually there or not.
I hate that, sometimes I only have the 2 keys in my pocket, House and Car.
Then i end up panicking and checking every pocket at ninja speeds.
Horrible ennit, i wish currency was made out of dark matter so i wouldnt need to check my jeans every 7 seconds
