rear light mk4 help
hi my rear passenger side tail light has gone out, i have replaced the bulb as i originally thought this was the problem, but found out that it still worked with the brake pedal pressed in. so i took the bulb to the local shop and purchased the same type of bulb and it did the same. i was then told it was a tail and stop bulb which i purchased and it didnt fit
does anyone know what could be the problem?
all suggestions are welcome
thanks in advance
kev
  • Views 681
