6N2 with Porsche D90's
mine are 6s at the fount and 7s at the back
simmy whats the et and size on yours
7's on front
8's on back
humm 25mm adaptors so i guess et 32ish at back and 35 at front
  • Replies 31
  • Views 6.5k
that must rub hard, mine don't even stick out that much and when i take corners they rub badly
they ruuuuuuuub like fuck on front! no rubbing on back tho :)
getting some 165/40's so its all good
are you getting 165/40 all the way around i got 195/40, 165 will be a hudgeee stretch on a 8 inch wheel
How low are you?
I'm down ~40mm, and thinking I'll be safe with 7's or 7.5 with 20mm adapters...
no 165/40's on the 7's leaving back as 195/40's bit of arch work i should be able to bring it back down another 20mm
How low are you?
40mm lol you wil lstill have arch gap..
you will be safe as houses.
I'm probs about 90mm ish
How low are you?
For various reasons I cant go lower at the mo unfortunately.
What about 8's at the back then? with 195/40's?
