weight loss ~g40???
Welcome to the forum!!
Certainly a G40 engine in a 6N2 wouldn't be the best power option? Mk3 G40's weighed about 780kg or less, but 6N2s are over 1000kg if I remember correctly? What about a G60 engine or (dare I say it) a VR6?
Anyways if you still want to go for it I can suggest this:-
- Fibreglass (or even carbon) panels where you can get them.
- Lose the soundproofing.
- Acrylic or polycarbonate windows.
- Lose the rear seats, door cards, plastic trim panels and parcel shelf.
- Bucket seats and (where available) alloy subframes.
- Lose the centre console.
- Ditch the spare wheel and jack.
- Quality sports tyres are always underrated!
P.S. who let the angry cats out in this thread?! (Just kidding guys stay CALM)
Edited by Chris_McCartney
  • Replies 45
  • Views 10.1k
THe GTI is almost the weight of 4 more people compared to the G40
:lol: I genuinely enjoy reading your posts Dave, as they never fail to make me feel better about myself, at your expense
That is because you are "special" as i stated in my previous post.
If you get you are jollies reading my posts then you need to find a girlfriend...
I've got the picture somewhere of your 2 by 4 efforts fixing that battery into the back of you are mk4 - classy! :lol:
To be frank - u come on here - give no decent posts - usually just abuse or "witty" remarks which are uncalled for - yet because of your clique status with the scene / forum people - there is never anything done about it.
If you remove a rack / steering arms / PAS block - i'm sure you'd be getting above 10KG's or is that now coming out of my arse too?
Is this a race for knowledge about polo's? shit u must be such a great person to sit and have a drink with and your substantial polo knowledge - i'm sure most of the ladies down the pub will be flocking to get thier polo's tuned by you Jez...
Personally i'd just like to see this guy get a decent car built and if the brakes do end up to be shit - and too much power a problem do you think after the conversion he would just crash it or simply change the brakes for bigger items?
I think he'd change the brakes after fitting a G40 engine into his 6n2 - it isn't exactly hard now is it...
But then you probably already knew everything about that because you are Jez! Oh BTW if anyone needs any cheap GTI parts - check this guys for sale post - loads of stuff there...
my issue was not the fact that the gti weighs 400kg's more than the flimsy mk3 g40, i had nearly completed my 6n g40 project which i have wanted to do for a while now and to finish it to a decent spec (paint etc) would cost me more than i was selling my polo gti for.
i just wanted to know if the 6n2 1.6 16v was a far heavier car than the 6n 1.4 16v to decide if it would be worth (+cost effective) putting the g40 lump into the 6n2? as it turns out (thanks to a previous post) there's only 59kg between them!
i'm sure i can lose enough weight removing the abs (pump, loom, sensors and ecu), aircon/climate control set up, seats, seat belts, rear interior, airbags, pas (rack, pump, pipes and bottle), cat, 15" alloys, disc rear beam, spare wheel and jack kit all of which i see as things i can do without, without any problems which will bring the weight down enough to make it worth while.
as previously stated i am not building a racer or overly concerned with power, so i'm not going to go stupid cutting bits of my nice car just to lose extra kilo's. i want a polo that is nice to look at, useable everyday and has an engine which i like, the g40 lump!
i've had tuned g40's, golf turbo, mk2 vr6, golf gti's, golf rallye etc etc i just liked the idea of the little g40 lump in a car with a decent front suspension setup (wishbones).
thank you for all you're comments, though few were encouraging....
oh and if anyone is interested, i'll have the car weighed before and after and have a brake power test done before and after by my local MOT tester and i'll post the figures so we can all see the results!!!
btw there is nothing wrong with my current gti brakes all recent discs and pads (genuine) fluid change and pressure bled. master cylinder is fine and servo holds vacuum perfectly but they are still disappointing!!!
The car is going to still need a rack and steering arms tho. The components that make up the PAS and ABS over standard non PAS / ABS will not account to much weight saving
Even if you just put the engine in the Mk5 it's still going to be faster than a GTi given the extra power and torque that's so easily available. A G40 (turbo?) engine could present a fine way of achieving 180bhp in a Mk5 without spanking the tits out of the 1.6 16v or spending lots of money on a 1.8 20vT conversion...it probably weighs less than both of the engines...definitely less the 1.8T. I always liked the idea of a G40 Lupo given the similarities size/weight to a Mk3.
Now that you can buy a PPP subframe for a Mk1/2/3 Polo using a Mk4/5 to get a car with wishbones isn't really required. I am sure a £550 subframe costs only a fraction of an engine conversion.
It's a strange concept fitting the G40 to a Mk5 given the minimal performance increase...but then it seems more acceptable to pop on in a Mk4. If it's only a 59kg difference then I wouldn't start with any radical weight removal, that's just like carrying 1 passenger...and a skinny one at that.
I wouldn't remove power steering or ABS. In a performance orientated car the power steering can be a great addition...but if you are not worried about outright performance then there really is no reason to remove it. Again the only real reason to remove ABS would be to stop it kicking in a race track...and since that's not the destination of the car the safety benefits would surely warrant you keeping it intact.
Edited by Tav
Jez get's regular abuse from me, don't worry :lol:
you cant run pas on a g40 without majour fabriction as you now have a charger where the pump used to sit as i found out while doing mine
luke
True story - well done on this months feature in PVW - cover car status - nice 8-)
Tav - I also like the idea of the G40 lupo / arosa - now that would be a laugh :lol:
If the 6n2 G40 does ever get built - it'll be unique for sure...
Dont even think i've seen one on the continent... :shock:
Buy a G40 and a GTI - that's my solution :D
Doesn't Jez get abuse from everyone? :lol:
I know this is not what you were asking, but it seems a little crazy to me to take off the rear discs, the GTi brake setup is FAR superior to the Mk4 drum versions and I would highly recommend keeping them on the shell along with the ABS and stripping absolutely everything else off it to get the weight down as much as possible.
I looked at using the Mk5 shell for my project but decided that I couldn't justify the extra cost of the Mk5 over the Mk4, plus I couldn't get the weight down quite as much (not much difference maybe but enough to bother me). I think the Mk4 isn't a bad idea as it's already got the subframe/wishbones on that the Mk3 is lacking and is generally a stronger shell (no chassis leg issues etc), plus one of the reasons I looked at it was for the ABS to give greater stopping power on a high powered engine.
If you've got a fairly high powered G engine to go in it you'll still get reasonable power to weight figures out of it providing you do put it on a very strict diet - no sound deadening, polycarb windows etc....
And guys, please can we keep the banter friendly in here, there's no need for us all to go bitching at one another, if it carries on I'll close the thread to put an end to it!
Sal. x
He has! He bought mine! and has a nice silver GTI waiting for G40 power...
That was my solution too for a while :-p
I thinks its a dumb idea, for the amount of difference in power between a gti and a g40 id keep the gti engine.
Winge and call me a idiot all you want i still think its a dumb idea, bu good luck :)
Edited by Dave-6N2
1.5 G60 thats never been done before :ninja: lol
POLO GTI BRAKES ARE A JOKE, ANY OTHER POLO WITH DRUMS HAS MORE BRAKING POWER
:? If thats your experience, there is something severely wrong with them
losing 60KG's is easy enough - PAS / ABS will cover that easily
Erm, doubtful
I reckon losing those two wont even save you ten
Jez is known as the local "know it all" guy - ignore his rambles...
I would say he is one of the "special" people around here :lol:
Did you not once use some 2 by 4 to fix you are battery in Jez?
:lol:
Your such a fucking specialist its unreal
Do you even know what your talking about?
Ignore my "rambles" as you put it? well as they are based on what I know, I would wager its a large amount more than that of your knowledge no? your posts highlight your complete lack of knowledge in the subject you preach, easily lose 60kgs from the PAS and the ABS? are you on fucking speed? or have you just run out of your prescription Ritalin? where are you getting all this information from? or does it come from the same place as 90% of your posts down in the deep brown of your arsehole?
and I have no idea what the fuck you are on about with saying "did I not once use some 2 by 4 to fix my battery in" and I expect you have no fucking idea either, (as usual) what you are even talking about
Nah - not 2x4 dave - close!
i personally think the cable tied in NOS bottle wins over the battery holder.
Sorry Jez - he has a point - even if he talks a bit harsh
Edited by youngprodigys
nos the g40 in the 6n2 8-)
Bloody hell lads this is mental but fun to read :lol:
i have to say i dont know a massive amount about the subjects but from my point of view which id like to express-
you say you want a daily useable car and yet you are on about a crash diet of ripping out all your interior, sound proofing, etc etc... seems a lil hypocritical to me? i personally really cant see the point as i cant see how you'd be able to shave 300kg off a GTI (down to mark 3 weight for example) without seriously comprising driveability and daily use, and tbh if you cant get it down to that sorta weight level i think you'd be comprimising what a G lump is all about- spanking the ass out of someone using a 1.3 lol. fair play to you mate its your decision but again personally wouldnt do it. i just thought id add that lil thought about it.
Mate you seem to be getting rather pissed off here, not everyones here to give abuse, I was just saying that G60's etc would provide a better power to weight ratio, but if you want a car thats comfortable then you cant really go pulling bits off it...
G40 will be a rev happy bugger, and quick off the mark too, but the extra cc's of bigger engines in cars about the same size will catch up. Would be a fun project but, I'd like to see it done.
Fuck this thread I cant read anymore lol.
Go for it and let us see some pics.
i wouldnt b pullin a gti to bits, y not pull a 6n to bits, prob slightly lighter to begin with and
there not worth as much as a gti if shit hit the fan.
and a dont see y you'd wanna put a smaller lump in, i dunno what power a g40 produces.
but with money you thinkin about throwin into it, abet if you stripped out the inside and sum engine tunin
if nessesary you could go faster and always put car back to standard if wantin to sell.
