Differences in an early and a late 16v?
I'm looking for a TSR Turbo conversion for mine....................
  • Replies 33
  • Views 4.6k
my valvers a t reg and i dont have rear disk but it has got abs and passenger airbag.
No Mk4 Polo came with rear discs. For that you need to get hold of a Mk5 GTI rear beam. Brakes are fine as standard anyway, they can handle the abuse i give them anyway! :lol:
they did, run out models and very late ones came with rear discs
i think the post regarding the early and late 16v engine is a miscommunication, i think it was said as a comparison of the mk4 and mk5 aub 100bhp engine!
..the 16v rear badge was placed on the top left corner of the bootlid wereas all the early ones i see they are down the right hand side near the bumper.
Sure about that? :?
Its just from what I've seen mate. My valver is a T reg and the 16v badge is on the bootlid in the top left corner. All valvers from T reg onwards that I've seen have the badge here. All the valver I've seen before that year have the badge near the bumper. Maybe it is just where ever VW felt like sticking them but thats what I've noticed so far.
So then...what you wanting for the G? :p
My early R reg valver has the 16v badge top left on the boot ;) My brothers P reg one had it botton right :paranoid:
OP
Probably just where ever the boy putting on the badge felt like sticking it.
If you dont know, dont post. This is what makes forums unreliable information-wise! :x
Very late models DID have rear discs.
Its an AFH thats in my new one - its had a freshly rebuilt bottom end with 4 new pistons all bored re-honed, new hearings and seal and a brand new VAG head with 16 new valves, springs etc and its been ported a good bit too. I heard ages ago that you cant chip the earlier ones, but you can the later ones?
Trust me its going to stay std for about 10 minutes (mainly because he lives 2 minutes away and I still have lights and stuff kicking around off my last mk4! Plus I think it would look sweet on my G60 steels!
I can re-chip early and late 6N AFH 16v they both have basically the same code and SO far have only come across 2 different ECU codes, today I was working on one with some difficulties that had a early ECU with Late clocks on an R plate which was a first for me, so some things are just gradual migrations.
The biggest thing to say on the AFH, i not sure if it was changed during the production run, but the thermostat housing is " very poor in design" in is made from a glass reinforced plastic and, I have had the failure on our P reg. I know of a freind with a V reg that had the same fault. The thermostat housing cracks resulting in the thermostat sticking closed which in term over heats the coolant, overheats the engien then if driven hard like this will kill the engine. Buy the replacement thermostat housing from VAG it has been re designed and is stronger around the part the breaks causing the problem.
So if you are doing major work it worth finding out if this is the improved version.
The Diagnostics port and fuse box is different on early 6N to later ones.
Looking at that pic, later ones had lightly smoked side repeaters aswell.
Just picked up my car today! Pics in the MK4 section!
