EKE 941T
hiya there love the conversion :) do you have any info on the install for the 16v as considering this for a mk2 golf.
gearbox etc combo n what other goodies are needed or need to be modded
cheers
Andy
  • Replies 52
  • Views 17.2k
pretty sure hes rocking a gt box with a gt fly as its a fair bit lighter than the 16v fly
oh and its also got a roll cage now :D
search afh in the forum.
Very similar engine block as all early polos... fits to 085 gearbox, so fitting the polo drive shafts are, no issue. Use the early polo fly wheel and starter.. If you run carbs, use ealry ignition, the one found on mk2 coupe s etc, plum carbs up via suitable pump. Change oil pressure and water temp to early type.
This engine is found in a polo 6n 1.4 16v not mk2 golf - which is a completely different engine
