The LuPolo Chronicles
Looks sweet, but hurry up and get it finished :lol:
  • Replies 265
  • Views 68.3k
Any updates on this? :D
alright nick, updates, erm sweet fa tbh!
need to get the rear drums built up on the powder coated axle then get the car up on stands and fit new brake lines and the rear axle, i want to whip the tank off and give it a coating of por 15 and underseal.
still have loads to finish off man to be honest haha, i think I'm gonna get up there at the weekend and have a sort out and get the car back out in the open to have a play with her again
woop
Ah, still a fair bit of stuff to sort out then.
Its gonna be mental when its done, can't wait to see it! :)
Did you decide on a colour scheme for it in the end?
Going up tonight to get the rear of the car jacked up, get the rear axle off and consider taking the tank off, might do that as a job for when it undergoes a full resto.
as for colour scheme nahh not really, I've decided its probably better to get her mot'd and running first rather than bothering now about getting it all painted up perfect.
My initial aim is to get the new rear axle on, brake lines made up, seat rails welded in for bucket seats, finish installing the engine properly (fit alternator, driveshafts, front brakes, pedal box) and I'm not considering a megasquirt for the engine management, a friend said he could make me an inlet manifold for bike carbs so if that does come about ill just get a megajolt for the spark. if i do go bike carbs tho I'm getting a foam filled engine bay as i dont want another inflamo situation again!
Cool. I'm well impatient and would probably paint a car first. :lol: Its good to see that you have your priorities in order. :thumbsup:
You've had an engine fire? How did you manage that? :?
long story haha
things are progressing now, rear axle off, brake lines removed, new ones are gettin measured up tonight, and rear axle bushes have ordered
r1 itbs and fannymold arrive this week too wooop woooop
oh and I'm buyin a derby =O
I've got a fire extinguisher now a wessner one, my mate told me its worth plumbing it in but to be honest id rather have it so i can grab it and run and spray exactly where i need it, knowning my luck the places i tell it to splat in the bay wont be near a fire that happens!
woopymcwoopenstien bitch tits
Loving it Saf! :D Can't wait to see it finished tho dude :thumbsup:
mmm itbs - yess theres a filter on wonky haha and theres a bolt missing from one of the blanking plates but ill get a replacement
and slimline ally rad =]
Edited by grungeisdead
fuck me thats awsome! love it.....how long left???
both for the lupolo aye, and not sure about timescales tbh altho I'm gonna try and finish it before the summers out =/
haha yeh boi!
Tonights jobs are to strip the spare GT rear axle i have for stub axles, back plates and other gubbings, measure up brake lines so i can get them cut to size and flared, get a cutting disc so i can finish the modifications for the drivers side engine mount.
I have to also split a gearbox and all the ancillaries of a GTI engine I've got as thats going at the weekend, good times!
Oh and if any one knows the VAG part numbers for rear axle bushes it would be muchos apprieciated!
Word
rough list of jobs
Braking
Measure and fit solid brake lines
Fit braided hoses
Remove and paint stub axles, back plates and drums from GT rear axle
New Wheel Bearings for Rear
Fit rear axle
Fit Handbrake
Fit Handbrake Cable
Fit Front Brakes
Fit Master Cylinder
Engine
Modify Drivers Side Engine Mount
Get GT Alternator and change pulley wheel
Fit Alternator
Fit ITBs
Clean Inner CVs and Regrease.
Fit Driveshafts
Fit throttle cable for ITBS
Replace Oil
Plumb coolant system
Fit header tank
Fit Downpipe
Fit Exhaust
Gearbox
Replace bell housing
Replace Gearbox oil
Get Hydraulic Clutch Parts
Refit Clutch Level to Gearbox
Attach shifter to gearbox
Fuelling
Fit Mk2 Golf Fuel Pump & Accumulator
Run braided fuel lines inside car
Suspension
WD40 and chain wax rose-joints
Fit Lower Strut Brace
Wiring
Install wiring for radiator, rear lights, front lights
Welding
Box section for seat rails
Things to Get :-
Rear Axle Beam Bushes
Emerald
Welding For Seats
Exhaust
8-) 8-) 8-) 8-) 8-) 8-)
oh oh cee dee eez
think I've found a relatievely cheap solution to the hydraulic clutch, and setting the brake bias for the huge ass brakes at the front and relatively small brakes the back. i think that since these come with the master cylinders too, its pretty bloody good value!
http://www.compbrake.co.uk/brake_p11.htm
http://www.compbrake.co.uk/brake_p12.htm
haha they work for me noobivore =D
mental :)
That top left jubilee clip is doing my head in man! its nit in the same direction as all the others AHHHH!
lol
It'd probably foul the throttle linkage otherwise - its the other seven that are facing the wrong way. ;)
aye thats right, the throttle linkage fouls is that jubilee on the top left is fitted otherwise.
the bottm left and 3rd from left at the bottom you wouldnt be able to get a screwdriver in if they were fitted in the same position as top left as the manifold studs would be in the way.
its fine ocd boy =D altho ye can get you tools out whenever you get to see it!
naw man, been too busy at weekends either working on the coupe or seeing this lassie, but the polos on the road and I've sacked off the bird, so good times, if my sis aint coming up at the weekend ill go mess about on it, take the engine out and strip the gearbox off it, need to get hold of a mk3 box so i can do away with the universal pedal box idea, saves messing about with hydraulic clutches and shit mk5 boxes anyway.
i might strip down the inner cvs, clean them up and regrease them as its something I've been meaning to do, and get the back plates painted up and start building up the rear drums.
i also want to shift the red golf out of my unit so i can put charlie murphy in there and get engine and box out of there to change the crankshaft oil seal, new ss mani as my current one has been merked and i really ought to measure the exisiting shims and calculate the new sizes i need the tappet noise has been driving me nuts.
it also needs to go in for welding too but i dont really want to start that until the insurance claim is worked out
well been at the unit today, cleaned up and painted the back plates for the drums, hopefully get round to ordering the new drums, shoes, brake cylinders and bearing kit to put them back together.
the axle needs to be removed anyway as the rear inner arches need wire brushing, and a couple of small holes patching up, and as the tank will have to be removed, i might bin it and go for a marine tank in the spare wheel well.
removed the original inlet manifold and offered up the itbs but noticed that the inlet manifold seemed to be fitted the wrong way round
the actual inlet manifold would bolt on, spun 180 degrees around, as the three widest spacing bolt holes attach at the bottom of the head, the three shortest spaced bolt holes attach at the top.
so surely the throttle bodies are fitted the wrong way round, as you would expect the fuel rail and injectors to be at the top! so I've flipped them around now anyway and will bolt them up in the week.
i think when the inlet manifold was built this was an oversight, as the vacuum take offs are now at the underside of the manifold, but thats no worries, just means they are slightly hidden from view.
cleaned up and painted the backplates and refitted them to the new gt rear axle. unfortunatly haven't got round to ordering the new shoes, cylinders, drums or bearings yet but the polo had to be made mobile as the golf is moving into the unit very shortly.
so its just rocking old drums, bearings, no shoes and old rear axle bushes as the brand new vag ones i had fitted got donated to the yellow peril for its mot. so 8 weeks with the arse on axle stands and shes now back on the ground, albeit unfinished, but the next task was to go about removing the engine and box
but got distracted and trial fitted the itbs and mani
whipped the itbs off and went to bolt up the inlet manifold, needed a couple of bits shaving off a couple of mm as they were being obstructed by the bolt holes for the factory engine crane hooking points and the bolts cutting down by 8mm as the new inlet manifold is around half the thickness of the old.
the main reason i went up was to remove the gearbox and use a polo mk3 box.
However the old gearbox mount has been cut out when they were welded extra box section into the front panel
so I've gotta weigh up the option of a hydraulic pedal box or getting a bit of the chassis leg cut off a scrap car and having it welded in.
if i could weld myself the latter option would be the one id choose, because i would still retain the mount for lupo gearbox so could pick and choose.
argh more decisions
