The LuPolo Chronicles
not updated this thead in eons had a welder come and look at the polo, quoted me 150 for all work including collecting and returnin so I'm made up, will be gettin booked in as soon as possiblle, cannot wait wooho
  • Replies 265
  • Views 68.3k
woop woop engine is coming out on sunday, gearbox is sold and the welder man is collecting it next week
happy days
Woop Woop 8-)
beautifil car
cheers mucker,
its all welded up now, back from holiday in the new year and it should have been dropped back off at the unit, so looking forward to getting it back together, still gotta procure a few bits and pieces but wooohooo super excited
well due to some random occurances, the engine is now no longer going to be a standard lupo gti lump, far from it.
Mk4 1.4 16v AFH Head
Lupo 1.6 16v GTI Bottom End
CBR600 Carbs
Schrick Fast Road Cams
It will be running the lupo 5 speed gearbox, unsure if i'm going to run cable or hydraulic clutch.
Anyway I used an afh headgasket, polo aex headbolts, afh relay roller(modified)
Note, 6n 1.0 AER & Non AVY GTI lumps have the correct length headbolts
6n Polo 1 Litre
036103384B
bolt, with multi-spilne socket head
M9X1,25X138 / AER,ALL
Lupo GTI
036103384B
M9X1,25X138 / AHW,AKQ,APE, AUA,BBY,AFK, ANM,AQQ,AUB
Polo GTI
036103384E
M9X1,25X97 / AVY
The correct part from GSF is
01163
CYLINDER HEAD BOLT
PO 1.4 AFK/AHW/APE/AUA/AUB Engines 99> & PO 1.0 AER Engine 96>99
£2.00 each and you need 10.
the relay roller
part number 036109244
the guys made me a bar threaded to 10mm at one end to fit into the block and 8mm to fit through the sleeve of the roller, it was impossible to drill through for guys with thousands of pounds worth of machinery so dont bother trying it at home, I'm glad i didnt bother!
cambelt fitted and everything timed up, engine plate and alternator fitted
I pick up my lupo 5 speed box from my parents house next weekend, and will hopefully have the lupolo back at the unit soon, its all welded up now, just waiting to get it delivered back
disclaimer :- I've not ran the engine yet, so it may all end in disaster but no harm if it does, as if it doesnt, its going to be a little screamer
Looking good,though i expect you'll be better using the less restrictive AFH cast manifold than that skinny thing,as the AFH ports are too big for it.
Nice find with the head bolts,i have to use standard AFH ones which are are more expensive.
I'm not sure if this will help, though there seems to be a VW cable conversion for a Hydro box?
I'd seen it mentioned over here
Hope that helps,
Paul
Haven't got access to EKTA, though I think this is the part number for the adaptor VW 02B141708A
Edited by wadders
hi matey, your an absolute star, i actually have one of those in the unit, as you do!
ill have a read up of that link tonight, cheers matey saved me over 180 quid!
hmm yeh i heard that but i never bothered measuring up the exhaust ports on the two to check the difference.
well the poopo gti manifold is going to stay until i manage to get a stainless 4 branch but not really on highest on my priority list
well the lump is getting closer to completion.
mated up with a lupo gti 5 speed gearbox.
all good bar the casings cracked where the mount bolts on, but ill just run it until it breaks.
i do need a new one of these if anyone has one (bell housing plate and gasket) as mine is damaged and leaking.
also picked up a set of CBR 600 FX carbs, and I'm getting a 2nd manifold made up this week and my existing inlet mani modified to be able to use the rather rigid and perfect mounting rubbers that are used on the bikes
updated the original post with a sorta lil backstory and up to date history for easier reading
well some updates on the shell
I poked this bit of filler to reveal this
which when provoked more turned out to be a full rotton corner of the wing but all was done well by Gray.
this was welded up but I couldnt get decent pics of it after in the dark
Welded up heater matrix
seat rails
patched up some holes on the rear panel
mk3 gearbox mount back in
dewipered bootlid
mmm
so need to get the bare metal cleaned up, skim of filler on the external bits and por15 on the seat rails, and get a lick of primer and paint on the fresh welded bits, I can deal with mismatched paint at the moment
then I need to get some 200mm drums and finish rebuilding the rear axle, and rest of brake lines, get all those plumbed up and bled and the engine can go back in along with the bucket seats and harnesses.
inside in going to be bare as fook, just 2 buckets, harnesses and a fire extinguisher.
its gunna be a foookin beast!
  • 3 months later...
well after another sabbatical, work continues on the mk1 this weekend,
some goodies to fit
200mm passat rear drums, back plates, stub axles and wheel cylinders, new vw shoes and bearings.
256mm ebc x-drilled grooved discs, lucas 54 calipers and ferrodo ds3000 pads
and the new lump is nearly done, just need to get a water pump, gearbox and clutch kit and woop.
its now an 1.6 16v sporting Shrick Fast Road cams. laaarvly.
will get pics after this weekends frolics
done today
undersealed rear inner arches after welding
undersealed welded engine bits
sprayed and undersealed the bucket seat mounts
removed old 180mm drums
fitted 200mm back plates and stub axles
fitted bearing races into new 200mm drums
fitted handbrake lever and front part of handbrake cable
fitted wiper mech - need the clips, nuts and grommets to attach the spindle bits tho if anyone can help
ate donuts drank irn bru and got baked <3
tomo
handbrake cable
circlip for brake/clutch pedal x 1
dremel rounded rear brake line
fit pedal box and pedals
steering column UJ
fit engine wiring loom
studs for seats and fit
keys
coupe s wheel
get brake lines made up
buy - 2 rear flexis, 1 wheel cylinder,
cirlip for throttle cable x 2
fit rear drums, hb cable, brake lines
fit front calipers/discs/flexis
gear lever
Edited by grungeisdead
got 28 days till the unit gets turned into a helicopter pad =/ so thats my deadline to get it running and out of there, if anyone wants to come grab some free/cheap parts to save them from mr scrapman, pop over
wouldnt mind a helping hand too =D
anyway engine loom found in the unit, main earths connected and fusebox screw in place, battery fitted.
32129_432207751342_511441342_5929732_164
32129_432207756342_511441342_5929733_474
badly need the nuts and grommets for the wiper mechanism, anyone got any kicking about
6,7,8 wiper locknut and washers and any plastic or rubber gromets
pics of seat mounted, pedal box and steering column fitted.
32129_432207766342_511441342_5929734_815
32129_432207776342_511441342_5929735_346
although i broke the clevis pin, so if anyone has one?
6a and 6b clevis pin
12 cirlcip
engines internals cleaned, sprayed down, drained and wd40'd up, sump bolted on to stop dirt getting in, but not cleaned up the mating surfaces or gasket pasted them up yet.
32129_432207791342_511441342_5929738_235
32129_432207796342_511441342_5929739_550
32129_432207806342_511441342_5929740_392
just need a waterpump and i can get the tensioners fitted, head on and cambelt fitted. then i need to get hold of a 5 speed box, or just bolt ad's 4 speed in as a quick fix
Looking good, been waiting a while to see this thing on the road, the helicopter pad thing is motivational !
indeed! nothing gets you going more than the thought of dodging helicopter blades midst car bodgineering.
also part number based fail, will grab it tomo if some of my parts come in the post and i pop up to the unit, i probably will do as i want to get this interior loom all wired up, tested and then stick the dash in
finally found all my hub mounting bolts so the front brakes are on - lucas 54 calipers, ferodo ds3000 pads and ebc discs
200mm rear drums and v dutty powdercoated rear axle, still awaiting my rear handbrake cable, when thats here i can get the bearings fitted. gotta order me wheel cylinder and brake lines tomo, but still desperatly need a clevis pin pedal pushrod thing for the master cylinder and the MC spacer. should also get hold of an uprated suspension kit for the rear as these shocks are truely pwned but should be mot'able for time being
grille and lights fitted, bonnet just rested in place, got another black one but need to get the vent holes are the rear welded up
trial fitted top fill rad, unfortunatly its gonna require some slam panel butchery, i think rather than just messily cut it out, i've got various hole saws, so ill make a circular cut out big enough to pull the cap out from and notch the inner part of the panel so i can get some grippy action around das cap. id rather retain as much of the original slam in place for fear or it collapsing!
note the grille cut out in this pic, I'm going drill the panel behind it, and fit an air scoop as fitted on GT's iirc and feed that over the carbs, eventually getting round to sorting out a plenum chamber for them
random pics
then spent the rest of the time sorting out bits in the unit, getting rid of pap ill never need, and boxing up the rest ready for an ebay flex.
heres what i uncovered from the house alone, its all gonna go on ebay at 99p starts when i get round to putting them up (next week or two)but if anyone wants owt gimme a shout
Mk1 Golf
GTI Magnecor KV65 Competition Leads Red with 2 Cable tidys
GTI TSR Drilled Airbox
GTI K&N Panel Filter
GTI Warm Up Regulator 438 130 073
GTI Cam Pulley - 056 109 111A
GTI Lower Crank Alternator Pulley
GTI Water Pump + Near new thermostat+housing
GTI Near new Bosch Starter Motor 055 911 023B
GTI Drivers Engine Mount - Rubber needs replacing
GTI Rear Gearbox Mount + Rubber
GTI New Downpipe Gasket
GTI Complete Series 1 1600 Metering Head/Injectors/All Braided Lines/Fuel Filter
GTI Semi Polished Alternator
GTI Oil Cooler / Hoses / Mounting Brackets
GTI Series 1 Contact Breaker Dizzy - Near New Condensor & Contact Breaker 049 905 205E
GTI Series 1 Parcel Shelf
GTI Complete Series 1 1600 Head / Cam / Water Housing / Inlet Manifold / Throttle Body
GTI Short Driveshaft - Good condition, relatively new inner CV
Bosch Starter motor 055 911 023L
Gearbox Selector Shaft
New Tensioner Stud
New Linkage Rod Bush
Tintop 3Door Green Tint Glass Front Passenger/ Rear Drivers / Rear Windscreen
Tintop 3Door Clear Glass Rear Passenger
Polo
Mk1-3 Lower Strut Brace - Adjustable but ONLY for cars up to -40mm.
Mk2 Polo Coupe S Contact Breaker Dizzy - Near New Condensor & Contact Breaker 023 191 009 / 052 905 205
Mk2 Polo Coupe S Airbox/Filter/Elbow
Mk2 Polo Coupe S Exhaust Flexi Section
Mk2 Polo Coupe S Metal Cambelt Cover
Mk2 Polo Powdercoated Water Housing & Thermostat Housing 052 121 117 / 052 121 171C
Mk3 lower steering cowling cover 171 953 516B
Mk4 Polo 1.4 16v Power Steering Pump Pulley
Mk4 Polo 1.4 16v Power Steering Pump Pulley + Pulley
Mk4 Polo 1.4 16v Crankshaft Cambelt Sprocket
Mk4 Polo 1.4 16v - Plastic Dizzy Cover & Lead Tidy 036 103 565A
Mk5 Polo GTI 1.6 16v Inlet Manifold
Mk5 Polo GTI 1.6 16v Cylinder Head
Mk5 Polo GTI 1.6 16v Red Rocker Cover / Cams / Pulleys
Mk5 Polo GTI 1.6 16v Standard 4 Branch Manifold
Mk5 Polo GTI 1.6 16v Decat Downpipe
Mk5 Polo GTI 1.6 16v Flywheel
Mk5 Polo GTI 1.6 16v Engine Wiring Harness
Mk5 Polo GTI 1.6 16v HT Leads Red x 4
Lupo
Lupo GTI 1.6 16v Standard 4 Branch Manifold
Lupo GTI 1.6 16v Decat Downpipe
Lupo GTI 1.6 16v Hydraulic Clutch Release Cylinder 600 721 261A
Lupo GTI 1.6 16v Engine Wiring Harness
Others
VW Cable Change Conversion for Hydraulic Clutch Gearboxes
Coil used in Emerald Setup - 089 04B 00104 - Leads from top left, clockwise are 14,32,27,41
Audi 3 Pod 52mm Guage Facia - 812 863 321C
2.5" NOS Veglia Borletti 8 Bar Oil Pressure Guage
BMW Smaller, Lighter Power Steering Pump Pulley to fit Mk4 Polo 1.4 16v - 1715769
52mm VDO 150 degree Oil Pressure Guage
12" Slimline Fan
Opel Manta GTE Tartan Recaros
320mm Aftermarket Steering Wheel
Slimline Ali Rad 12"H 1.75"D 20.5"L 23.5" between mounting lugs
Yo dude - what was that rad made to fit? How much you want for it and the fan?
its got water outlets at the cambelt side with a little take off for a header tank, i was going to flip it round so i could use it on the small block but not sure if i can just block it off.
40 for rad, 30 for fan with mounting kit
best for mk1 golf big blocks as the water outlets are the correct size
irn bru!
brilliant build so far mate!
sorry for the tread jack but how much for the VDO gauge? is it a pressure or temp as you say '150 degree pressure' doe it come with sender?
Epic, epic build! Keep at it mate!
