The LuPolo Chronicles
irn bru!
brilliant build so far mate!
irn bru ftmfw =D danke
sorry for the tread jack but how much for the VDO gauge? is it a pressure or temp as you say '150 degree pressure' doe it come with sender?
any time max, tenner for the guage, needs a tidy up around the metal face, comes with holder, bulb but not the nuts to secure the holder.
no sender I'm afraid, unless you can use a water temp sender, if so I'm sure i can find you one.
edit :- it is a temp guage btw
Epic, epic build! Keep at it mate!
cheers mr munkeh!
Edited by grungeisdead
  • Replies 265
  • Views 68.3k
I think I've got an original mk3 GT air scoop thinging if u want it? but I'm guessing you will make your own :)
wouldnt mind one to be fair, saves me bodging something to fit.
fancy donating it to the cause =D i wanna see your mk2 aswell
No worries its no use to me now :p
il have a root round in the next half hour to try and find it, the mk2 is just sat on the drive with no fuel pump atm :cry:
dankeshun, i have a fuel pump off a mk2 gti if its any use, completely diff to yours tho =[
if it puts fuel in the engine it should be fine, as iv got a adjustable regulator to help things....
il see if i can dig the GT stuff out now.
come grab it tomorrow then mate wa16 8uq any time after 1-2 ish, gimme a bell before hand if you want 07950 675 910 will be spending the morning putting nays 1 litre back together as the head is off it
how much u want for it?
Cant seem to find the stash of GT parts i had yet, will keep looking tho.
was after about 40 quid as its complete with all fuel lines and accumulator but you can have it for 15 squids if you want dude =]
sounds good, will keep you posted if I'm coming down or not tomoz :thumbsup:
Hoping it uses the same "2-pin" connector?
The Blue Coupe S sitting on your driveway in one of your pics is now mine :)
B34TYG
Just fitting a gear linkage and clutch and she will be back on the road!
Good build, good luck with getting it finished before you get chopped up by a helicopter :/
dunno laddie, will have a look for you
B34TYG
wooop, that belonged to my best mate char, i had the pleasure of driving that wee beasty to its mot =] i fell in love with it, but had just got myself another mk2 at the time so couldnt justify it
oh any pics of das comet blue now matey?
well productive day was had today,
we put nays mk3 polo back together after he took apart to change the headgasket and a few other bits, and i got to pilpher some much needed bits for the mk1, muchos kudos to nay
anyway bits done on the mk1
* rear wheel cylinders fitted both sides
* rear shoes fitted both sides
* got a nos handbrake cable but its such a random design, need to fathom it then i can fit it tomorrow
* new clevis pin fitted on the pedal box, all circlips in place and nos master cylinder fitted
* interior loom fitted
* dash fitted
* clocks/speedo cable fitted
* earthes fitted.
* made cut out for top fill rad
* mounted front number plate
* mounted both front seats
* fitted washers and locknuts for wiper mech and fitted wiper arms (well one, as the other has gone awol and they are mk1 polo specific!)
* bonnet catch and release lever fitted
* fitted new door seals
and the new oem shoes to keep with the lupo theme when i get hold of some tyres, if anyones got any 175/50 185/50 195/45 14 inch rubber lying around gimme a shout
picked up a new water pump today and getting at gt 5 speed box from dubmania tomo, so the engine should be in the car one evening next week, proper buzzing
list for tomo
horn + hornpush
rear handbrake cable
full brakes lines + bleeding
relay - lights
harnesses
ignition wiring loom/coil/tca
power distribution block
rear number plate light and heated rear windscreen
list for week
rear beam bushes
water pump / cambelt
oil pickup/sump
flywheel/clutch
clutch release bearing/gearbox
crane
bonnet/bonnet stay
parts list
gearshift base
afh starter motor
thats enough to jog my memory for tomorrow
couple of crap pics
fitted full new solid line and flexis, solid lines from rear are 15cm and 40cm too short so will get some extra lines made up in the week
fitted brake pedal return spring
wired up coil and ignition loom
working rear electrics, unfortunatly told the welder to weld up the hole for the numberplate light wiring DOH! so will drill that out
fiited water pump / cambelt and timed up engine, will refit sump tomorrow and then the lump is ready to go to the unit.
need to pick up das GT box from hoppys in the week and then chuck the engine in there woop
looking good man, them starlights should look mint on the mk1.
not had much time latly to pick up that fuel pump, nor the cash.
been fixing 2 cars atm, 106 - clutch, megan - cambelt snapped :evil: , notice there both french :roll:
doing this just to fund getting the mk2 on the road :p fuking weather is slowing me down, no garage/unit ftl :(
yeh its dread mate when the rain hampers your progress, feel free to take the fuel pump when you can get up and just gimme the cash as and when.
poopy french motors =[
should get 40 notes as soon as i fit this clutch, not as easy as i first thought, but Mr haynes should get me thought it :p
and if i sell the 106 for anything over £700 i get the profit, WIN! :lol:
so i should be down soon enough :)
got the brakes lines finished, handbrake cable fitted and all bled. happy days
harnesses nearly finished just need to drill 2 9mm holes in the subframe box section for the last harness mount
new wheels are here woop just need some tyaaaaaaaas
also collected my gearbox - 5 speed AHD - gave it a clean and quick lick of paint
tomo picking up crane and going to stick it in the car, good times,
also got sorted out a starter motor and alternator thanks to mugz
still havin no joy with the front lights
Lookin good dude and dnt mension it for parts u will just have to let me have a drive wen its dun lol
Safe
brand new stainless box made by double S in devon - 50 quid bargain
stuck a battery on the golf to move it out the way, stuck the oz's on the front of the mk1 so i could roll it out the way and shove the golf in the back. some daylight pics
and with the gearbox painted, clutch and pressure plate fitted, gearbox on (massive thanks to turbodailys genuis tip for getting the box clear of the flywheel, i owe you a wispa xD)
its a bit toight like
gotta butcher together a gearlinkage, and rob the rear gearbox mount off the mk3, change the fluids, connect driveshafts and get some tyres, and we should be alot more complete, but happy days. i was smiling like a cheshire cat when we rolled it out int daylight, i <3 lamp but i <3 the mk1 a lil bit more (just dont tell lamp!)
and nays crotch grab sneaked into shot
haha i love lamp <3 ! :lol: epic mate and u gotta love the crotch grab and my wheelspin machine in the bk ground :lol:
NAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
haha great sucsess ! ................................................................................
....................................... nattttt !
pause
naaaaaaat
harnesses are now fully mounted happy days!
starter motor fitted
found a few gear linkages in the unit so retrofitted all that linkage, just waiting on a new shift finger in the post and i can get the gear linkage up.
found the driveshafts i need, just need to replace a couple of cv boots, some fresh grease and they are good to be connected. if the adapted lupo shafts are too long, ill use the polo ones, as the different cvs have the same spline on the driveshafts, id prefer to use the lupo ones as they are near 3-4 times wider in diameter than std mk1-3 shafts.
fitted the bonnet and adjusted so it sits nicely and latches properly.
just niggly bits left now, my biggest pain is going to be getting the headlights rocking, once they are done I'm on the home straight, hopefully the manis should be ready in the group buy soon,
anyway only a couple of pics today as i was covered in gear linkage putty stuff and cv grease, laaarvly
am i right in thinking there is a plastic clip that stops the bonnet lever marking the paint as it goes down, or was that omitted in favour of just holding it forward as you close the bonnet, so it clears the slam panel
great sucsess ! :lol: looking gd it looks almost complete !
