Arch enemy
Looks pulled?
  • Replies 40
  • Views 4.6k
Glad i had my arches done now! got pulled tonight for a plate light out . . weird thing was they didn't even mention my wheels?
I was sure thats what they'd pulled me for lol
This is what a member on BMWowner wrote up
Following on from this thread: 328 BBS Rims - 245/40/17 rubbing issues
Faced with the above issues I decided that having my rear arches rolled would be the best way forward so after a bit of digging, and a couple of recommendations from members here, I got in touch with Phil from http://www.archenemy.co.uk
After chatting about the problems I was having with Phil he agreed that having the arches rolled would give me the clearance I was looking for. Phil explained exactly what was involved and said he'd shoot a questionnaire over to me via Email so he could assess the work I required and ensure there wasn't anything that worried him with regards to carrying out the work on my car. Sure enough 5 minutes later I received a quick Email questionnaire that he requested I fill out and send back. The questionnaire was very straightforward and was clearly designed to give Phil a general view of the condition of my car before he agreed to book me in i.e. rust / repairs carried out.
With the questionnaire completed I fired back at Phil and he booked me in for the 1st August (I had contacted Phil on the 28th July)
Sure enough Friday morning Phil turned up at the time we'd agreed . He spent the next 5 minutes or so checking my rear arches and inspecting their condition. He also checked where the rubbing had been occurring on the passenger side and gave me a couple of options:
1. Have a partial lip roll done - just enough to give me the clearance at the rear of the arch as only a touch more would be required in my particular case
2. Have a full roll done to give me plenty of clearance all the way around
He then said to have a think about it while he got his kit and to let me know once I'd made my mind up. To me this was an excellent sign as Phil clearly outlined the risks and benefits associated with both options and I didn't feel any pressure to choose either option . In the end went for a full lip roll as I wanted to be sure I'd have plenty of clearance whenever I had four people in the car!
With my choice made Phil cracked on with the job
As soon as he had my rear tyres off he called me over to take a look as he'd found a bit of surface rust on both arches - particularly annoying as I'd had one of the arched professionally repaired not 6 months back .
To my surprise he offered to use a grinding wheel on the inner lip to remove the surface rust, then apply some anti-rust paint and then finally use a high spec seam sealer to ensure weather protection......I was delighted and of course took him up on his offer!! At the very least it means it won't get any worse and gives me some time to get the car booked in to have them sorted again . He did say that work of this type was temporary and that I'd need to get them looked at properly in my own time i.e. he was not offering a cheap rust fix, he was simply trying to eliminate some of the risks associated with rolling an arch with an uneven surface due to rust i.e. uneven arch lip.
Phil also took the time to explain that there is ALWAYS a risk associated with rolling rear arches. He also explained that the arch would look slightly different after the rolling was completed - nothing to write home about but side-by-side you'd notice it. He showed me where the changes would be most visible and how I should expect the arch to look once he'd finished.
Finally Phil gave me a form to sign - the form basically limited Phils liability and again explained that there was risk associated with the process. Some people might see such a form as something to worry about, for me personally I took it as a good sign. Phil wasn't trying to say that the process was absolutely risk free (which it isn't) and was clearly outlining the risks - it was then my choice to accept that risk or he wouldn't be able to carry out the work I wanted. To me that demonstrates a commitment to ensuring I didn't agree to the work without fully understanding and accepting the basic, and in reality fairly small, risks associated with the work.
With the form signed out came the tools and Phil got cracking:
Work Begins
Surface rust removed and anti-rust paint applied
Seam sealer applied
With the rust removed and the arch protected Phil cracked on with the actual rolling:
Drivers side - pre-rolling
Drivers side - post rolling 1
Drivers side - post rolling 2
Passenger side - pre- rolling
Passenger side - post rolling 1
So there you have it.
Overall I'm delighted with the work Phil carried out and wouldn't hesitate to call him again should I feel the need for some more arch work in the future .
Hopefully the above should give you an idea of what to expect when using a reputable company and may give you some pointers you could use to spot a bad one !
a good place to get arches done is at www.wide-wheels.co.uk
they do um at a really good price
one of the guys on the SXOC bought a pro arch rolling tool for about £400, did one arch and then went back to the scaffy bar, said the tool was a bit poor for £400
Went on the arch enemy website to see if they were any good and from looking at their pics they seem pretty good, i was looking at their prices and i thought how cheap there rates were, £135 to flare all 4 arches :shock: too good to be true isnt it?. Anyone used them?, Cheers.
Here's a vid of them in action from Youtube:
ArchEnemy
i would go to a body shop, heard manyhorror stories about these people
had mine done by arch enemy at the weekend, all 4 flared, mine were done done by Robert Ryan. i'm more than happy with the end result, 2 didn't turn out too well but that was due to me already butchering one of them and the other was due to the front wing being a second hand replacement that that already had a crease in it near the arch that i hadn't noticed when i bought it. the other 2 came out really well tho, especially with how much he had to pull them ('is this enough mate?,' 'nah keep going' lol), he was a top bloke and explained all the dangours and risks involved in what i wanted, he also said if i replace the wing that was already creased he would flare it for free as he wasn't impressed with how it turned out. mine still need tidying up with a skim of filler due to how much i got him to pull them, but before he started the arch was sitting on the tire about an inch into the tread, now it clears the tread and is nowhere near the tire, wouldn't hesitate in using him again :thumbsup:
shoulda kept the rust imo :thumbsup: looked ghetto and dare i say it 'ratty' :lol:
yeah but it was only the one arch that was like that, maybe i could of paint stippered the other 3 and waited for them to get that bad, could of took a while tho :lol:
besides with the rust it wouldn't of looked this good...
8-)
looks shit! :lol:
nah dude it does look well better now youve had them done..you sorting the hole in the boot???
i examined my rust a bit more last night and the shell is parting from the chassis around the drivers side rear arch and sill...now who's fucking rat??? :p :lol: hahahahahaha
got a lot of cutting and welding to do next week :D
Edited by Genesis Jim
i bow down to you, that sounds like some terminal rust right there :lol:
yeah i will be patching the hole up but not just yet, got a list of shit that needs doing in the next couple of weeks and thats right near the bottom tbh, i can drive it with a hole in the floor, i can't drive it with the engine missing :lol:
Yea I'm really tempted but it the money thats the issue lol camber maybe an option for now
thats just what i oped for, camber is a 20quid cheap option! should look very nice with some camber 8-)
camber for 20 bucks?? where?
that's right all hail me :lol: hahaha
I'm Officially the Un-official King of Rat..... :lol:
yeah man i would leave my rust where it is but i need an m.o.t so i have to patch it up,and plus I'm respraying the car in a pastelly blue (matt like) and I'm gunna put a new arch in while I'm at it,its all dinted and that....
so are you minting this scirocco or what? what are the plans?? keeping it shitty?? lots of questions :retard:
Slammed Shitters ftw
mate you stole my idea, if i hadn't of got the rocco my gtd golf i've just pulled apart was gonna be a light matt blue, great minds think alike lol. should look sweet tho mate fo'sho :thumbsup:
yes jim its staying shitty, my inspiration is the interceptor from mad max.
slammed shitters ftmfw!
interceptor FTMFW!!! my all time favourite car is that :D
yeah keep it nice 'but' shitty :lol: if that makes sense haha
yeah man light matt blue should look boss,i was gunna leave it with the pinstripes on but my mate bollocked me when he saw the rust :lol: told me to get it sorted then just have it resprayed,my brother can spray and has all the stuff to do it so i thought matt paint would be cheapest and give me the desired look on the car...i used to work in a body shop building old aircooled campers,i built 3 and prepped all of them for painting,i just haven't been given the chance to have a go at painting yet....it should be mint when its done :D
great minds do think alike your right :D
