Hawker's White 6n
looks wicked James :-D
  • Replies 379
  • Views 61.1k
Thanks mate
nice one dude, i grabbed my material off babz on sunday but still havnt got the glue lol
I'm jsut wondering how to go about the edge of the sunroof, handles & visors?? :/
if i did do this how does the roof lining come out? and i just thought iv got a sunroof too so thts some more trimmin to do
can't help you on the sunroof as i wouldn't know, grab handles and sun visors are easy, just ake small holes where the screws go
Looks good mate. I think you should spray the grey bits though on the seals. I'm going to spray mine black when I do my headlining!
Cheers, yeah i will do, the grab handles are drying as we speak, i sprayed them in gloss black. I'm going to try and dye the sunvisors black too, don't know if it'll work though :lol:
Not sure if dye will work, becuase they're a kind of plasticy material aren't they? Probabably better off spraying them matey. I bet your annoyed that you gotta take the door seals off again! I hate doing that as I'm running loads of ice wiring down the channels which will all fall out and become dis-organised!
it's wierd sort of material isn't it, oh well i probably will just spray them, tell you the truth i need to sort my wiring out anyway :lol:
8-) i might get on with my a b c pillars this week, and leave the headlining for a couple of weeks until I can be bothered to spend a whole day in the car!
The C pillars were a nightmare to get the material smooth, ended up having a bit of it creased in the corner :-( try and get some one to help you do the headliner when you do do it as it helps just to have that extra pair of hands when laying the material down onto the glue.
Yep mate will do, I always have some company with me when I work on't car. Get bored otherwise!
Btw, how do the A- Pillars come out?
has the glue on the headliner started to sag the material?
i was wondering if that happens??
but it looks top mate, good work :thumbsup:
No sagging atall, sat under the sun for about 9 hours on Friday and it hasn't sagged abit
They're all on clips same with the other pillars, just be careful not to snap the clips like I did on a couple :oops:
Hi-temp contact adhesive will prevent any sagging!
The stuff I got was 70 degrees resistant, worked upto now so we'll just have to see, wait for a really hot day to properly test out.
Just heat it up with a hairdryer or something?
What, make it sag? It got pretty hot the other day for about 7 hours and it stayed put, so I think it's all good
No I just meant it could be a way to test it, because you said you were waiting for a hot day.
It should be fine mate :) Looks like you've done a top job!
Well I try my best :lol:
Grab handles sprayed gloss black, you may have noticed that one is missing it's because i messed it up so got to do that one again :oops:
primered
painted
Edited by H@wK£R
goo job mate! i still haevtn started mine :-( i bought dye for the door seals, let it all do its shiz then washed them as per instructions and it all washed off :-( GAY! What you doing about door seals dude?
was going to dye them but not now :lol: probably just try and spray them?
