Oil advice and recommendations here
Cheers mate just got some castrol magnatec 10w-40 semi-synthetic oil from your website, got a nice little free gift too :)
Mike
  • Replies 132
  • Views 63.4k
  • Yes - its just passed its run in mileage (1000 miles without breaking 4000rpm - 3000 miles with no topspeed runs and regular checkes of the oil level) Probably going for the 5w-40!
  • i use Castrol 4T (for bikes) 10W40 Mikey for your engine is better if you use bike oil becouse is made for high temp and revs
  • Hi I would use a 5w-40 synthetic and service it every 10k/annually rather than using a VW long life service schedule. http://www.opieoils.co.uk/c-656-5w-40.aspx Out of those, the best ones are t
Any advice on oil required, please feel free to ask as I can help you
You will also find some useful info on my website here
http://www.opieoils.co.uk/oil-and-filter-s...ce-pack-vw.aspx
All the best for 2009
Guy
vw
polo
1997
1896cc AEF Diesel engine
no engine mods
road use
soz don't no average temp, it just sits half way in the gauge when in use
what oil should i be putting in my enigne???
cheers
10w-40 semi synthetic with regular changes.
Have a look at the Fuchs XTR 10w-40 here http://www.opieoils.co.uk/c-657-10w-40.aspx
Guy
vw
polo
1991
1043cc spi
road use
85 - 95
which one do i need!!
cheers
Make: Vw
Model: Polo
Year: 83
Engine size/type 1.4 golf engine
Any mods: stage 2 head port and polished, gt cam, motorbike carbs, 4-2-1 exh manifold.
Type of use (road/track): fast road but track very soon
I'm running 10w40 castrol gtx atm
I'm afraid i do not know the oil temp
Make: VW
Model: POLO
Year 2001
Engine size/type: 1.4 16V (AUA) covered 80,000 miles
Any mods: NO
Type of use (road/track): ROAD
Additional info max oil temps: Factory temp
Current oil used: Unknown (Just purchased car for my mum)
What engine oil would you recommend and at what intervals should it be changed? & would i need to change the gearbox oil at all?
Also would like info about this car please:
Make: VW
Model: GOLF GTI/BAM 20vt
Year: 1992 (Engine from 2000 model i think)
Engine size/type: BAM 1800cc 20v Turbo
Any mods: JnR Airfilter/FMIC/Magnex Stainless/VXR Injectors/4bar FPR/DTA managment & pushing 270-280hp
Type of use (road/track) Road & maybe the odd trip to santa pod
Max oil temps: What would you recommend?
Current oil used: Quantum Silver Synta Semi Synthetic
What do you want a recommendation for? Engine
Edited by oak dub
Make: VW
Model: POLO
Year 2001
Any mods: NO
Make: VW
For the Polo, use a 5w-40 from here, the gearbox should be fine unless the shifting is a bit lumpy
For the Golf I would use the same as above but change more frequently if tracked
Guy
Make: VW
Model: POLO
Year 2001
Any mods: NO
Make: VW
Guy
Thanks very much for the reply Guy :)
No probs ;)
polo 1.4 16v 100 bhp plz due oil change would be helpful thanks
1997 999cc Polo (1.0L). I was told 10w-40.
most protective engine oil?
Make: VW
Model: Golf
Year: 1997 (MK3)
Engine size/type: 1.9SDi (Diesel)
Any mods: Cold Air Feed, K&N Panel Filter, Diesel Pump slightly turned up
Type of use (road/track): Road, Motorway, Rarely Hammering it
Additional info (max oil temps, current oil used)
Currently using fully synthetic (cant remember what though), Mileage just over 170K Miles
The norm would be for someting like a 10w-40 semi synthetic with regular changes, as an upgrade for better protection a 5w-40 synthetic can be used. Have a look at the likes of the Motul 8100 Xcess 5w-40 and the fuchs titan Supersyn Plus 5w-40 here http://www.opieoils.co.uk/c-656-5w-40.aspx
Guy
hi
vw scirocco 1.8 carb 1988
no mods
fast road
i dont know the oil temp
doesnt have any form of oil cooler (some sciroccos have one on top of the filter)
its coverd 230000 miles so i put some 20w50 in it as that was advised to me by a spanner monkey 8-)
thanks rich
If the engine is in good shape despite the high miles a 10w-40 semi should be ideal with regular changes, if it uses 10w-40 then up it to 15w-50. No need to go as far as 20w-50.
Guy
Make: vw
Model: polo
Year:1990 mk2
Engine size/type: mk3 gt engine 1272
Any mods: air filter, 4 branch with s/s system skimmed head and flywheel
Type of use (road/track) road and the engine has 250miles to be run in
atm I'm running 10w40 castrol gtx but i think i need more protection
Stick with the GTX untill run in is complete.
Then switch to a 5w-40 full synthetic, something like the Motul 8100 Xcess 5w-40 here http://www.opieoils.co.uk/c-656-5w-40.aspx
Guy
Make vw
Model polo
Year 1992
Engine size/type 1043 aau engine code
Any mods induction kit,7mm ht leads bosh super 4 plugs,ecotec valve,performance back box and removed centre section of exhaust.
Type of use (road/track): road
Additional info (max oil temps, current oil used) : engine temp: 90-95 degrees. currently running gtx magna tec 10w/40
hi
vw polo
1.6 16v gti
2001
90000
bmc induction kit, custom remap,denso iridium plugs,magnecor kv85 ht leads,jetex cat back system,4-2-1 stainless manifold
engine oil please buddy
road use
A decent 5w-40 synthetic changed every 10,000 miles or once a year, what ever comes first.
Brand wise, Motul, Gulf, Fuchs and Silkolene well worth a look http://www.opieoils.co.uk/c-656-5w-40.aspx
Guy
