Paint repair on rear arch..
Hi, just got a bit of minor bodywork to sort on my G40, it has had a respray and the finish everywhere else is excellent, but on the rear, it was run with ET24 wheels and spacers, and has rubbed the paint off the arch, and let some water in and its starting to flake, the arch has also been rolled, but its been done well as far as I can see.
I'm thinking, after some research, and reading the guide in practicle classic mag, that I'll need etch primer, as the cars white, will I need white etch primer to get the best results? also the paint finish is pretty thick, so will I need highbuild primer to build it up to the level of the rest of it?
I assume I will need to sand back any paint that isnt 100% solid and start from there?
Was going to buy this http://www.paints4u.com/ProductDetails.asp...Mainselection=4, but will I need etch primer instead of the one supplied? Guessing I'll also need some tack rag things as well?
Any educated advice would be greatly received!
Rich
  • Views 759
