Jake's G40 a.k.a Project Unicorn
Updated photo better late than never....  this is the SFS G40 coolant pipe kit
  • Replies 84
  • Views 60.1k
  • Today, 8 Years after becoming a CP member, I've become a Mod, so I thought one of my first jobs would be to tidy my build thread up even though there is lack of progress. Every other month at a minim
  • Had a shipment from VW Classic Part through VW Heritage including Wing, Gear Gaiter, Bushes, Door pins, Rubbers, Clips, Grommets, Keys etc   Also swapping my axle out refurbishing it and rep
  • MOT PASS! no advisorys or fails at all :)
My clocks only had one bulb left working and I wanted oem ones so got the latest version from VW today they are now orange holders and we're £7.74 for the three.
Bought some parts from AVS spares and Pete G40 ready for when they are needed, rear axel bush's, fuel filters,  uprated temp thermostat, rocker cover bungs,  pedal rubbers etc
Also got some new front speakers as my old ones had faulty connections and to be fair they are over a decade old.
  • 4 months later...
Also swapping my axle out refurbishing it and replacing all bushes bolts etc same with the fuel tank, pump and lines.
Also found out that the MK1 golf wing grommet is spot on for the G40 wing as the Polo part number is different and obsolete.
Progress is still happening :)
  More purchases .
More updates include;
Cleaned coilovers with fresh powdercoated springs,
Fuel pump brackets all blasted and powdercoated, new OEM parts when rebuilt,
New Fuel tank blasted and powdercoated,
Rear G40 axel blasted and powdercoated, rebuilt with new OEM rubbers and S/S bolts where non structural, new OEM where structural.
  • 5 months later...
Masking off for UPol Gravitex  underseal
Is that the same as the Raptor ? as i sell that stuff at VW Heritage :) Looking good though
I'm not sure what you mean by raptor, the underseal?
No idea,  heard good things about what the upol gravitex can cover
