Front Passenger Door bump has killed the lock ...
Hi,
I have a 97 polo with a dent in the front passenger door and a broken door lock.
It wasn't me, bought it off less than careful flat mate ...
Looking at the reg papers there is a 6NZ in the VIN ?
The key part of the lock is completely shagged as far as I can see.
The key doesn't turn at all in the lock but the door can be locked and unlocked from the inside with no trouble.
I have the haynes manual but it just sort of says take it to someone to fix it.
The book says that the 97 models on have a different door lock assembly and you need a special VW tool to reassemble it?
I guess I've a few questions at this point, trying to figure out my options:
If the barrel is knackered can I get a new barrel for my old key?
If I get a new barrel like that can I get a door from a breakers and just stick the new barrel into it?
Breakers near me have a door for a 96 and a 98 polo same colour.
Can I take either door or am i better off with the 98 door ?
The door I have has electric mirrors, if I get another door off a breakers can I fit my old working mirrors to it or do they all come with 'em ?
Oh yeah, the boot lock stopped opening as well so I opened the whole inside of the door and a piece fell out.
It has a small black plastic arm bout inch'n'a half long on with little cups on each end, like a double ended ice cream scoop.
One of them is on a ball joint on a zigzag piece which has two lined up holes like the hinges on a door where the pin goes in.
It looks like a catch of some kind so I figure (?) the cup goes onto the ball joint on the part of the lock that rotates with the key and the catch part sticks out to into the path of the inside bit of the door handle / catch?
I got a bolt and nut and fitted it so that the catch bit sticks into the path of the door catch on the inside of the door so when you squeeze the boot door handle it catches the piece I found and turns it so it flicks open the lock by pushing on a corner of it which moves in and then the lock clicks open and the door opens?
So far so good, there's only two problems:
1 is the little cup keeps coming off the rotating-lock ball-joint.
2 Turning the key the whole way moves the catch around and past where it gets caught by the door handle catch.
It turns back and forth on a path which puts it in the way of the door handle catch and then it keeps going and ends up too far along it's path
and it's out of reach of the door handle catch as it moves on it's path.
Was there or should there be a little spring or somethgin to hold it in reach of the door handle catch?
I'd take pics but I don't have a camera.
Any answers to any questions mucho appreciado amigos.
Ta buckets,
B.
  • Views 636
