6n2: rear washer pipe work/rear door-hatch
'ello all.
The water pipe for rear washer- has split when the cleaner fluid (read:water) froze, in turn has split somewhere with-in the connecting rubber seal/cover going from roof area to the top part on the inside of the rear door/hatch.
The question is - does anyone have a Haynes pdf for 6n2? As I'll need to strip the rear panels to get to the pipe work to replace it.
Thanks in advance and all that.
Frazer
  • Views 955
