2 G40s
First one...
1992 Genuine Capri green G40 on 108k miles.
Full spec...
Stage 4 rebuilt Jabba charger 3k old
Alloy intercooler
68mm pulley
SNS anti lag Chip
Green G60 injectors
Fast road cam
Vag decat downpipe
Dewedged throttle body
Boost return mod
60/40 lowered (koni iirc)
Braided hoses
14" Ra's
Toad alarm with central locking on the button all working spot on
Scirocco tilt and slide sunroof
Guy before me gave it all new...
Clutch
Head gasket
Rocker gasket
Cambelt
Thermostat housing
Blue temp sender
Rear brakes
Down pipe gasket
Uprated exhaust hanger
Dizzy
I've changed...
Oil + filter
Coolant
Inlet gasket
Plugs
Leads
Cap
Rotor arm
Coil
And just put new Greenstuff pads, and ATE powerdiscs.
Bodywork is clean, usual few dents, a bit of surface rust coming through on one front wing and a door has been replaced but is a very slightly different shade of carpi green
Interior is clean, seats arent ripped or worn.
Tax and MOT is out this month, after £2100ono with 12 months mot and 6 tax.
£3200 if you want a 1341 conversion.
Located in Surrey, will give it a clean and sort some pics out this week.
Second one wont be ready for a couple of weeks unless you want to take it without mot.
Its black, about 145k miles on the shell (although it had a vr6 plasma dial clocks conversion with mfa stalks etc)
First of all its been repaired at some point in its life which I only found out once the v5 turned up which was nice of the new owner. :x
Its got...
PSD full blend 5k old
68mm pulley
SNS anti lag Chip
Green G60 injectors
4 branch exhaust manifold
Jetex exhaust
Boost return mod
Bodywork is cleanish, paints not so good in places up close.
Interior is ok. Drivers seat has a worn bolster.
Full clifford alarm and immobilser.
Engine has done just over 100k miles, its had...
Oil + filter
Coolant
Clutch
Head gasket
Exhaust gaskets
Inlet gasket
Plugs
Leads
Cap
Rotor arm
New dizzy
Low mileage driveshaft
With 12 months mot and tax I'd be after £1900ono.
  • Views 497
