Mk2 Golf - 3 Door Project - £80
This will need to be trailered and is almost a complete car. It is generally solid all over, but it will need a completely new inner wing on the drivers side.
It's a Mk2 Golf Driver 1.8 with approx 75k on the clock. No Tax or MOT and is currently declared SORN.
Resprayed over the top of the original white with red oxide primer before I got it, there is a little overspray on the seals, etc.
The engine is pretty much complete, has the standard carb although I'm told it's not 100%... The previous owner did have it running with a weber carb (not included) with no issues
I was told by the previous owner it has had a new clutch which has only covered around 3k, and that the gear box is spot on with no crunches, etc
Exhaust wise it has everything but the back box :D
It's currently on some Mk2 steels, nice and ratty :p and although it's been sat on the drive for a few months, handbrake has been left off so should be ok and hopefully not seized...
The interior is pretty much complete, just lacking the important front seats and not so important rear door cards...
I'm looking for £80 as I need it gone off the drive... It's located in Winsford, Cheshire (CW7)
I will get some pics up tomorrow (weather dependant) :D
  • Views 396
