Rear Badge...
How is this done? just painting it?
  • Replies 8
  • Views 1.2k
I just took mine of rubbed it down with a scotch brite, primed it, sprayed it black, laquered it and let it dry, then stuck it back on with a hot glue gun.
looks top and cost pence.
Yeah i just used a hairdryer to get mine off, gave it a rub with some sand paper so its got a rough surface for the paint to stick and then gave it a few coats, i used matt black so i didnt need to laquer it :-D
I just popped mine of, masked up the rear plate, few layers of cream....then sanded down the badge with 1000...primer and then black....then superglued it back on....
that wiper blank is wicked :D
...to answer the question-spray the badge black by the looks of things :thumbsup:
want to make another one with a boot popper fitted inside so i can pop the boot by pushing it...
sweeeeeeeet :D:thumbsup:
thank you kind sir's
