New S/wheel, Now Indicator Stalks?
So, I've bought a new wheel, with a mountney boss. Took hours getting the coller off my '91 GT steering column and now I've came across another problem:
There's a lip on the back of the boss which doesn't sit flush inside the indicator stalk assemley, with it not sitting flush I can't get enough purchase on the bolt to tighten the boss on.
Can I fit a Mk3 Golf stalks for example, Would anyone know if the centre bore is larger because right now its probably 3-4mm too small.
Failing that, what bosses are people using? I've rang Mountney twice and got the same answer that the 'M237' I'm using it right but now I'm not terribly sure.
Any ideas? Thanks
  • Views 557
