Madnes Or Genious
you are choice from here init mate. idea. dont be a sheep, be different. put a vr lump in it. turbo that
its vr money though
  • Replies 90
  • Views 6.3k
BUMP
Don't forget to smooth the exhaust mate, I heard that gives 60bhp alone....
lmao avin a new exhaust built anyway , bt smoothin will get u 2-3 bhp
morning bump
its a non turbo lmao no wonda mi mk3 could keep up , with a 1.8 turbo what box do u run ?
you're mk3? do you have a vr6 mk3 golf? if you do then i say a 20VT would kick its ass from here to timbuktoooo...
20VT is a lighter engine, produces more power and has more tuning options
VR6 - Heavy V6 with not much power.. only thing that can be done is turbo or supercharge it and that takes alot of time, effort and money.
20VT all the way.
20VT all the way.
nope had a mk3 polo runnin 88 bhp, striped out veri lite
dumbness! :lol: not worth it mate, stick to a tried and tested method of engine building or fit a different engine, not point in givng yourself un-neccaserry ball ache!
You sound like a technical genius, I say go for it!!! Sounds like it will be rapid... And it will be so unique, a half ci, half si running petrol. Should be really powerful! :paranoid:
was thinking a diesel bottom end and box because i can run a stupid boost from the turbo and it can handle it , with Nealy 2.0 cm2 capacity in the cylinders , may run a golf gti 2.0 head or a valver head and gti intake ecu etc , or get a entire engine , be like a 2 l 16 g40
Sounds like a shambles if I'm honest. But go for it, make sure you get a build thread up on here though!
will do i kno most people doubt me but i do know what I'm doing
how will a diesel bottom end take loads of boost? It'll be too high compression ratio to even run NA on petrol let alone any any boost what-so-ever. What are you trying to achieve and why don't you just do it with a 1.8 20vt engine?
until the head goes BLAM and flies off? it's the head that will take the pressure, not the block...
and what ^^^^ up there said! CR will be way out :retard:
Edited by richie_stix
Haha Genious :roll:
lol
rate funny
i want pics of smoothed exhaust..... :-/
you sound like you dont really know what your duin...
1.8t wont be as fast as your spi rocket with its interior stripped out to get rid of about 4 bags of sugar in weight
hmm, maybes you need to find out what a real fast car is like....not thinking spi's are the fastest cars on the planet
Skoda VRS engine FTW!!
Although the guy asking the question sounds a bit numb, some of the replies on here arent half stupid.
Right, its a totally logical plan (and one that has been practiced many times before)
Lets list the advantages...
Derv bits are cheap,
The bottom end is hard as nails because its designed to run at over 20:1 compression ratio.
So the first problem is that the diesel probably runs flat top pistons, So when you fit the petrol head, although it probably has a combustion chamber, the compression ratio is going to be high. So fit a set of turbo pistons out of somthing that fits.
Asuming the petty head bolts straight on, all you need to worry about is driving the cams, shouldnt be a major issue.
If its a 16v head the chances are the diesel exhaust manifold/turbo isnt going to fit, so you need to sort out a manifold.
Other than that its all electrickery and fab work.
There are guys in NZ using a 3.0l diesel engine from a nissan patrol and bolting a skyline head to it for 600WHP on the standerd derv bottom end.
yeah, you can use 1.9tdi bottom ends on 20vt's, but i think this is a TONNE of work when more power could be made, with ease.
1.6 gti lump with a 'charger?
What a load of bollocks.. just let him get on with it.....
Do you honestly think someone that thinks smoothing an exhaust gives 2-3bhp on a Mk3 Polo, can actually build a working, custom engine??
JUST NOOOOOOOOOOOOOOOOOOOOOOOOO!
:thumbsdown::crybaby:
omfg stfu you really dont have a clue what the fuck you are talkin about do you
1)smoothed exhaust,biggest load of bollocks I've ever heard
2)if you have done engine conversions in the past then why dont you do this one without asking people aswell
3)that 1.3 did not have 88bhp,my old polo gt made 95bhp so how did a more or less standard one make 88
it wernt even multipoint injection
that is very true,and before he comes back with a smart comment about me not knowing what I'm on bout i do work for bmw and work on m3s and other things daily so i think i may just know what I'm talkin bout
