Bugger
Bought a bog standard 1.0 Genesis in november, every car i've ever bought has turned into a project, planned on just a simple tidy up, lowered and a nice set of wheels, nothing spectacular.
First i wanted to get the car sound, fuel tank was leaking so i replaced that last month, motor has only done 77,000 but had an annoying slight knock between 1500 and 2000 RPM, also had the common oil leak between the head and block, done some research and decided the knock was the cam followers, an oil change can help but rarely does and the oil looked fairly fresh anyway so i bought a new set of followers, a headgasket and a new cam belt.
Done the job last weekend, went ok appart from not being able to get the bottom pulley off to get the timing belt done so i'll leave this till i can get a garage to slacken it off with a buzz gun, fitted the followers and the headgasket, changed the oil, used a good quality 10/40 semi synthetic and a new filter, motor started fine but is now worse than before :cry:, tappets are now rattling and the original annoying knock is still there, only reason i can think of for this is that there is slight wear in the cam too, the original knock may be piston slap ?
Still have the old lifters, thinking about sticking these back in to see if it helps but the orders are now mixed up so it probably wont, i'm loosing patience and enthusiasum with the car (not even looked at it since last weekend), it's tidy enough with a long MOT and drives nice, has had a lot of money spent but wondering how far i want to go with it, maybe cut my losses and buy something better.
  • Views 464
