Mirror - Colour Coding
I have the black plastic mirrors. They are electric. No indicator lights on them. I would like to make it so that the top is silver like the higher spec polos.
I could get a paint job done. However I think I was being offered 100E for the two which is a bit too steep for my liking.
Where can I get the caps from? Is it a big job to replace the black ones, bearing in mind the electrics?
Thanks in advance,
Emmet
Edited by thejoker
  • Replies 6
  • Views 1.8k
The black is mine. I would like that silver look. Cheapest solution?
'Cheapest solution'
Spary it your shelf
'Cheapest solution'
Spary it your shelf
Is that a very tricky and dodgy job?
Na Not reli take it off and spray if you do it right it will be mint
