Job Lot Off Mk4 Polo Bits, Every Thing For £5,, 22++ Items
you will get every thing below for just £5, and £12 postage unless u want to sort that out u self,, just £5 tho the lot (may split but rather not
timing belt cover
bottom fan belt engine pully (this is the one on the engine)
top timing belt pully
drivers side inner wheel arch
passanger side inner wheel arch
lambda sensor and manifold (manifold damaged)
out let manifold
fuel rail / line
complete distibutor ( connector block damaged)
full oil sump / pan
oil cap
oil cap again
passanger engine lifting eye
drivers engine lifting eye
engine mount
alternator mount
engine wiring harness
knock sensor
fuel regulator
oil pressure switch
IF I FIND ANY MORE BITS I WILL ADD THEM ASWELL
bottom end off a apq engine,, 1.4 8v, - got a slight piston tap........ PICK UP ONLY ON THIS
  • Views 119
