Laquer Problem I Think?
I own a pol 6n and the whole car is spotless apart from this one door where it has these 3 horrible white marks on it. I think they are a laquer problem , I'm not too sure as I'm not familiar with body work. I will post a few photos of the marks. The marks arnt huge but are noticeable and i would like to get it sorted out :D
Any help would be really appreictaed or if u need any info on the marsk or more photos then let me know.
Thanks a lot.
Jack
  • Replies 10
  • Views 1.4k
I've seen a few 6n's with paint problems and lots more with rusty marks and paint bubbles.
They look like bubbles, If you pop them then there would be rust underneath, You would need to wet/dry sand it back and re-prime then paint the areas effected.
Ok thanks.
So i need to pop the bubbles..
wet and dry the area? what numbers? very fine i guess?
And prime the areas
Then paint the areas.
How can i paint just the areas with a can ? :S
I'm a big time armature
Sorry !!
are there any mechaphiles in your area? :ninja:
I wouldn't like to say as I've only needed to do repairs on sills so I've just used whatever is lying around to tidy and clean the area up before under-sealing it.
doing parts like doors would need a bit more expertise than i have.
looks like you would have to paint a fairly large area to get a colour match or get dent masters or whatever they are called to do it
mechafiles? :S
hmm :S
I'm not to fussed about it being perfect , i just dont want them so noticable , if they were green rather than white it might looks a bit better...
I dont want to spend loads on getting it sprayed up!
I dont suppose anyone knows a rough price of how it would cost to sort it out profesionally?
id suggest you pay someone to do it , if you haven't painted before its hardly a beginers job
ah ok then mate , yeh i think that sounds like the best idea!!
mechafiles? :S
in other words Car Perverts. :lol:
