Pioneer Headunit 7" Screen, Tv Tuner, Cd Changer & Ps2
I'm selling this full Pioneer set-up which consists of...
Pioneer AVX-7000 (7" screen headunit)
Pioneer AVM-P7000R (Audio Visual Master Unit)
Pioneer GEX-P7000TVP (Hide-Away TV Tuner)
Pioneer CDX-P25 (6 Disc CD Changer)
Sony Play Station 2
All cables to wire this up are included. Also have 2 PS2 controllers with extentions so you can play on it whilst sat in the front of the car. The invertor to run the ps2 is included. The 2 remotes for the headunit & tv tuner are included.
You can control all your other ICE as well like components, subs etc.
Here is the tech specs for all the units.
Monitor-Format: 16:9
Display type: Wide Screen LCD Colour Display
Display size: 7 Inch
Screen Coating: High quality anti-glare coating
Installation possibilities: In-Dash
Fully motorised display with auto dimmer: Yes
Front panel: Partially detachable front panel with warning LED
Dual Button illumination: Yes
D/A Convertor: 1
AV Bus Input: Yes
Installation: Hide-away
Mosfet power supply: Yes
Maximum Power Output: 6 x 45 W
Remote control: Yes
Cellular telephone & navigation audio muting: Yes
Tuner: AVM-P7000R
Tuner Type: High-Speed PLL ARC-5 Intelligent RDS
Station Presets: 24
IP Bus Control: AVM-P7000R
Multi-CD control: Yes
Source CD control: Yes
Voice Commander Control: Yes
TV / DAB Tuner Control: Yes
External Unit Control via IP Bus: Yes
Audio / Visual: AVM-P7000R
RCA Preouts: Dual
Subwoofer output: Yes
RGB Input for navigation system: Yes
Independent AV Selector for front display: Yes
Independent Video source selector for rear display: Yes
RCA AV output: 1
Source Level Adjuster: Yes
Picture Colour/Sharpness adjustment: Yes
RCA AV input(s): 2
RGB Output: Yes
Type: PAL, SECAM* TV Tuner (* not compatible with SECAM L)
RCA video output: 1
RCA video inputs: 2
Station presets: 24 (12 TV1 / 12 TV2)
Antenna: 4 Channel diversity system
Built-in FM modulator (for original headunit connection): Yes
Country setting: Yes
Independent audio video selector for front display: Yes
RGB input for navigation system: Yes
RGB output for front display: Yes
BSSM (Best Station Sequential Memory): Yes
Remote control: Card-type remote included
Picture adjustment: Yes
IP Bus Input/Output: Yes
Pictures...
These units still sell for well over £500
£270 Collection ONLY!
Email Address: joe2187@hotmail.co.uk
  • Views 282
