Just Been Smoked By A 1.8t Ha
ADAPTORMAN, are you the guy who built it?
adaptorman built it for the other dude i believe, hes the one thats been posting it on retro rides.
what mine?
  • Replies 120
  • Views 10.6k
yep affraid so ,, :lol:
what mine?
yearh that true ,did a quick engine transplant ,,so dont let anyone tell you there a over hard job to convert as companys wanted 4k ,ekkk to convert one ,it tuck me approx 2 months and most of time was from waiting for parts,
Surely the VR6 is a bit tired if you have had to rebuild it? Modern engines usually go for 200k+ before needing a rebore.
And low rev running in is over rated if you read up on it, its ok for your bearings although not very critical, but can be poor for your piston rings, as they need a bit of stick to bed them in and its important to do this quite early in their life. The key thing is not getting it too hot for too long. short blasts are usually recomended because it gives the rings some stick but dosent get the pistons too hot.
And chrisn curbourough is so narrow :? its in a few mini dvd's I've got and its just wide enough for them.
Not wide enough for what? Am I hearing excuses? :lol:
It's used for the MSA British Sprint Championship - as pure a test as you can get.
This is at Curborough and has a 2.6 litre V8 in it :-D
Trevor%20Willis_%20Curborough%20Test%20D
Edited by Chris Eyre
the engine wasnt tired ,i only rebuilt the engine ,because i turboed it and didnt want it to fail when in boost , ,,so as poloman wanted the engine, i down graded the turbo setup not the intails , any engine that has been rebored and pistond ring mains tc ,has to be beded in due to the facts that when a engine is rebored it leavs scor marks and if the engine is reved when first fitted it will damaged the out piston ring edge witch will cause poor starting.low compression and burning of oil ,thats why ,usely the oil is also changed as well ,once it reached its bedding in ,so the bores are more smooth and rings move more freely then the engine can be operned up on the thottle but every engine regards petrol diesal ,and differnert alloys and cast metals ,,but I've told mr polo man,,,but things dont seem to sink in........,
The bores are scored intentionally to bed the rings in and to retain oil. Smooth bores = worn engine. Because the rings are never exactly the right shape when new they have to wear to the right shape, this is why a softly softly running in process can result in reduced ring life.
Back in the day engines had to be run in steadily because of poor dimentional accuracy on bearings/bores etc, so too many revs could result in excessive expansion and interference. With modern accuracy this is now virtually redundant for bearings.
Rings work on pressure, the higher the cylinder pressure the harder the rings are forced out into the wall of the cylinder, and forcing them into the cylinder wall pretty hard very early in their life is key to a good seal.
wonder when its guna close......
Edited by tony100
Jesus christ, what a load of squabling in this thread end of the day id have either of the engines in my polo and would especially love a vr6 in mine,
but then again i wouldn't be a cocky noob about it!
i agree loseless therd which hasnt gone anywere but down hill ,,waste of space ,,,I've put a 24v vr6 ,then turboed it and then made it 4wd ,, this illgive these little chavs somert to worry about..
haha!
ok ok so hes not the fastest but this vid still shows how wide the track is :o ITS TINY
Possibly the slowest car you could have picked. When the action warms up a bit, it looks like this:
Of course for those with no smokin' skillz, it might not be of too much appeal :-p
vr6 lumps will need the timing chain tensioners doing just after 100k i believe it is. only real weak point on a pritty bullet proof lump, but if you've got the engine out why not rebuild it first? makes sense really.
In all fairness this thread is like Jade Goody.
haha!
It's a sprint circuit, more about the driver than the power of the vehicle. I went along to this last time & a cracking little day......no stress & no worries, interesting to watch and see how the different cars handle from a spectators point of view.
the caddy 8-)
goes on too long, and most people wish it would go away soon?
or that its famous for giving a bald bloke a nosh on live tv?
Because its expensive, time consuming, and if the milage isnt daft then its probably nicely worn in. Plus the chances are you will end up fitting cheap pattern parts instead of the perfectly good genuine ones that were in their.
Anyway the bloke said he rebuilt it to make sure it was strong enough for the turbo he fitted which is totally fair.
If I'm honest I just thought polovr6man was bulling about his 3k rpm running in.
Edited by Tommo32
not a place i would try to compare cars power wise.
It would because it reflects real performance, and handling.
And it would sort this debate out (main reason I posted tbh) :-)
I've been doing events there for >10 years, and with knowledge of past results, you'd be very surprised
the BS i saw was the 3k run in when jamie clearly said to me he was caning it
and the fact polomanvr6modifiedbreakingforsaletbhftwwordinitblad said he could "have" him if he wasnt running it in
oh and the stupendous Bhp from a chip :lol:
oh man this thread,
it has been announced that as her last wish jade goody wants to be cremated and put into little velvet bags that way everyone that attends the funeral can go away with a goody bag :lol:
