Indicator Noise?
I'm guessing the relay for the indicators in my mk5 is playing silly buggers as after you've indicated and the stalk resets, it keeps clicking behind the dash but twice as fast, is this likely to be a fuse problem or a knackered relay?
Forgot to add, when the turn the key (turn electrics on) the relay starts clicking
Edited by jonPDpolo
  • Replies 21
  • Views 4.4k
put you are hazards on walk round and check all you are bulbs 1st mate
Usually when the indicators speed up it's a bulb that's gone out. So yeah, as above check all your indicators are working.
Did that yesterday, all working :?
get you are relay out and do the drop test , this can be done on bulbs 2 lol get it and throw it on the floor if it smashes it was no good lol , na seruiously u need a new relay only a few quid
make sure no wires are cut or if you have changed lights you cut the wires and connected wrong ones
Was thinking it may be a new relay, but the full beam won't stay on, it'll only flash so am guessing it may be the stalk?
remeber your lights ahve to be on for your main beam to stay on. i made a idiot out of myself doing this before i thought the main beam wouldnt stay on but you have to physically have your main headlights on in order for your main beam to stay on
hope this helped.
Edited by Stonez
have u managed to sort this out yet cause I've been rolling around with my hazards on (with fuse out) for ages to stop the clicking!!!
doesnt really work cause i cant use my hazards and i have to unpress the hazards whenever i want to indicate..anyway..
instrutions on replacing the relay would be great...!!! thanks
forgot to add... its clicks constanly and all bulbs work
Edited by KuansWagen
Anyone know how to change the relay etc? or where abouts it is?
i get a clicking whenever I'm driving around or the ignition is on, i dont know what it is, is this related?
Almost 100% faulty relay, I've had this on a few cars.
TBH though, it's never stopped the indicators working.
As for location, follow the clicking noise :)
cheers i will see what i can do and let u know the results
okay well it was the relay, when i unlugged it everything still worked though, whats it meant to do?
Edited by dub17
yeah mine make that clicking noise to but all way works so not sure but i will see what dub17 does first then if he fixes his get him to do mine lol
u meen so if i f*ck it up u can just avoid making my mistake lol
nah its simple.
Edited by dub17
unplugs like that, then u unplug the little lead from the back of it.
just incase anyone gets the same problem, cheers
so you are goign to fix mine no w
hey guys i had this annoying clickin noise and it was coming from my haz button, all lights were ok and bla bla so anyway i took my indicator stalk off and cleaned it till it looked like new! now i have no clicking noise and all is gooooood! just thought id say that all you guys on here are great with your hints and tips, i couldnt have fixed my motor otherwise.
cheers dudes n dudettes
Telboy84
any help on how to remove the stalk?
You'll need the remove the steering wheel
is it easy to put it all back? and how can you get to the screw holes?
it seems really hard to access.
thanks
i tried and failed. i couldnt get the steering wheel off in my mk5.
i removed the plastic covers and saw 2 holes behind the steering wheel. there doesnt seem to be screws in there though?
or if there was i couldnt see properly.
also tried the other method and tried to find the relay. i followed the noise and removed the dash and it was coming from hazard switch. couldnt find the relay though.
help please!
