Mk1 Vw Golf Caddy Pick,4wd 24v V6 Turbo 56k Heavy
I knew I recognised this! You live down the road from Dearne Valley College don't you?
At the base of that hill.
I pass this motor everyday; saw the exhaust - Always wondered what lurked underneath that bonnet!
Sure know what your doing. Who's is the other Caddy parked up nowadays?
Rob.
the other was for spares but really its a better caddy then the one I'm doing if anyones after a restp mk1 caddy 1.6d no t and 300 and tow it away ,I've been offer 200 for the rear bed alone , :-)
  • Replies 117
  • Views 29.8k
Shit the Bed!
This is an awsome Project!!
Rob.
Wow.
What brings you to club polo then, if you've got a caddy?
Previously owned a polo?
Rob.
Wow.
thanks guys ,nice to have a good responce ,,,i fitted the a guy a vr6 in a polo and thought id thow somert in a caddy really ,,as i make out fit need be ,ie i fited a quadcam 3.0 in my daily pickup and aex police t5 engine in a old beetle
Serious skills! :|
Serious skills! :|
na just passes a bit of time on :lol:
some headlights and hose clips arived to 2day too ,just awaiting more bits and bobs
Serious skills! :|
When am on the road, in a couple of months (Still 16 on a crap 50cc scooter) I'll race you in my mk3 polo. :lol:
intresting read.. fair play. :nod:
look forward to seeing it run sometime.
david.
david.
cheers dave slowly getting there ,,
just finished the brakes off and anyone after some cheep alloys I've 4
decided to re done the proshaft as i wasnt happy with it (angle wasnt right)
these alloys are going cheep anyone after a set of 4 with legal tyres 5x100 one centre missing 70
You are one crazy mofo with some serious skills!!
you actually are god at cars.
clearly are insane.
cant wait to see it all done :)
nice one guys glad u like the home made idea ,, mind if all goes to plan it maybe a crazy caddy ,,if not ill rip the lump out and thow it in somert else ,,
small update ,more home stuff this after
fitted the lights
the finished off my home made rear bumpers
Damn it, just passed you. Saw you working on it. If only a didn't have to go to college; would have stopped off to say 'Hey'.
lol
small update
rear wheel spacers arrived
thought id fitt hem
then added the pair and looks loads better but unsure if ok ,as i reckon it should be because the rear is light and the tyres have a great dish inside and out side so should put extra load on the wheel bearings ,,,any thoughts
small update ,, modifyed the anti roll bar 2day and fitted it ,, seems to have stiffernd the rear end up
got a front one to make fit too
then thought i better straightern the rear bed up a bit ,
I've a bit more to do ,beat means removeing a few bits so ,that ill sort at a later date lol
tryed the tailgate for rough fit
next when I've time is is get rid of the banara tailgate ,make it look a bit straighter
small update not mutch modifyed the rear handbrake this after
brakes and handbrake sorted
Some crazy skills there, would love to see the run down toe strip one day
Amazing work :D
Amazing work :D
cheers ash ,well one day it may happern when is another story ,, unless i get bordf , and think chuff it and cut it up ,,
front anti roll bar fitting next ,may help
29d8oyw.jpg:lol:
You've got some wicked skills mate! keep us updated :thumbsup:
cheers bid , ps for all of you are guys runing rears disc conversion and have handbrake cable probs use ,mk3 golf vr6 cables there fit a treat :-p
started n the drivers side floor to strenghern it up so first removed the old channeling
then made a new one with nice thick steel
welded that on and cut the other rottern part out ready for some thicker steel
added a another plate
then added the thicker one to strenghern the floor and chassi mount up ,
then did a few flooor patchers ,, thinking about it i wish id just cut the complete floor out instead lol ,, but a bit late na
then thought check for a few bits to sort around the body ,
finished off the rear quarter ,too
few holes welded up
then finshed weldeing the bottom door corners
so decied to remove all the underneath underseal , stressfull ,lol
which found a few more holes lol twating vws lol
then decied to do all the under archers and got a bit carried away with the grinder and polished the coilover leg up ,, god knows what i was thinking lol
makes things look rather tidyer then rusty steel and welds showing
same with the rears too
then welded the old truckman holes up and a tad a spray to stop rust until a later stage
then again i had to make a small spacer for the coilovers ,because with runing bigger mk4 cv jonts there were catching on the cv rubbers , so alterd the holes and made the spacer and welded it in ,so when heavy braking is needed the suspension leg carnt drop ,,and cause any problems , then gave it a clean up ,,
then as it was getting dark ish , thought id give the calipares a quick goinging over lol
from this
to this
my paint then tbh honst ,,
keep them like this, metal looks cool. love this thred :)
LEE
LEE
nice one lee may shine them up at a later stage
right had a few hours free so thought id start on the dash
first rip it out
then make a few strenghing bars
i wasnt sure were u mount the dash too above or below the window rubber
got best i could looks ok , but any idea i do with the side window covers as theres a gap ,
but its fitted ,and pref the black dash to grey ,, still was a bit tight on the ends and had to trim ends of the dash near the window corners to fit
another prob looks like the gearstick assembly will need moveing back a few inch too
so whos up on how the hell i rewire mk3 vr6 clocks and coloum storks into the mk1 wireing ,, as I'm stuck ,,,
so 2day i neeeded a break an decided to find some cheep seats after a quick clean i think they will do the job as they evern have runners so , easy to adapt
nice flat backs too ideal i reckon for a caddy
and i was going to fit a golf ball type gearknob but it dosent look right after bending the gearstick , so had to buy a nice 4 motion one to match the runing gear
alfa seats.. mmm this is gunna look awesome mate...
