Mk1 Vw Golf Caddy Pick,4wd 24v V6 Turbo 56k Heavy
Shame this hasn't been updated :(
  • Replies 117
  • Views 29.8k
hi ill get a few pics but person the 24v engine failed a few times with boost , mostly pistons, crank bearings, so i fitted a old mk3 vr6 obd1 , 640cc tunie and turboed that and I've not looked back since , bodywork still the same , and runing very well , engine spec wossnerr pistons, sp conrods, arp bolts,hx40 turbo, 6speed gearbox , 312mm discs, electric sterrings, same polo interior, 4wd ,side pipe usel home mods runign 30psi of boost , and loving it , but due to fuel prices ill back taking off the road and just use for summer fun
Any working videos of this? Need to hear/ see it, looks mental!
Fair enough! What you had out of it?
will get some vids as off to pod this year , fingers crossed
regards bhp or speed 30psi boost on a holset hx40 turbo , (nice to max the boost gauge out) according to speedo needle pops off the limit :-) I've snaped a few cv joints , and 2 intakes , one head gasket, and can burn 4 tyres out in 4mins 25seconds , gives some a little idea , but useing slicks is hard very gripy when warmed up so usely breaks drive shafts instead
search for adaptorman on youtube theres a few on there but that was the r32/24v turbo engine , as they look nice but , i pref the old 12v vr6 stand a lot more boost and less issiues , ill upload a fewpics
few picsfirst megasquirt ms2 ,soon to be converted to ms3 :-)
boost leak tester very handy
12vr6 set up ok at 15psi but hadheat issiues so needed to in prove but room is a issiue
made this and intakes were nice and low until i rised the boost to 20psi
3rd attempt 8mm alloy heat treated
5n92jl.jpg bingo holding 30psi
lastist engine shot
2wm2nix.jpg evern thow its runing well i personaly wont to start over with ms3 standalond ecu as it should be a better set up and live tuning too
next i thought id make a custom 76mm downpipe and somehow have enoe room to fit from the hx40 holset around and under the engine missing 6speed gearbox/transforbox /steering rack/and propshaft
got the oldgrinder out chop and weld up
then buzzed the lot together
next need to make 2 side pipes ,once I've rewired the engine bay
Holy shit dude, this is awesome! Major props are due
well more upgrades are needed so now bought the lateist megasquirt ms3x great bit of kit and ill be runing 6 ls2 yuko coils , engine runing boosting really well up at 30psi :-D 4wd no engine/gearbox issiues yet
wow awesome report....
just got bollocked at work for wasting time looking at forums...... well worth it!
  • 5 months later...
just read this whole thread through from start to finish, truly inspirational stuff!!!
you mentioned a beetle earlier in the thread, not by chance the one running a volvo lump that had a thread on VZi quite some time ago?
keep up the good work mate
yep thats mine too ,,,
plus i upgraded my caddy and home diy turboed a mk5 r32 turbo , bit tight but fitted and running
also turboed my mk3 vr6t golf which will be coming up forsale on ebay too
Mad fab skills mate
cheers pal ...
<3 wow unbelievable skills
just fun stuff tbh
Oh my fooken days you are a ledgend! how have i not seen this thread! I wish i had the skills you have! Hats off to you mate its awesome.
