250+bhp '02 ibiza
Hi all the time has come to sell my ibiza, dont really want to but I'm looking at buying a T5 van.
Spec as follows:
Engine:
- K04 turbo
- A-M Motorsport 9 core front mounted intercooler
- 4'' inlet filter with polished cold air feed pipe
- Jabbasport map
- 3" blueflame downpipe & 100 cell race cat (wrapped in graphite impregnated heat wrap)
- Full cat back stainless steel Jetex exhaust system
- forge recirculating DV 007p
- Uprated engine mounts & gearbox mount (from badger5)
- 4 Bar FPR
- Silicone hoses and polished pipe work for intercooler
- Blue vacum hoses
- Polished rocker cover
- Polished inlet manifold
- Polished oil cap & dip stick
- Seat sport upper strut brace (powder coated to match wheels)
- N249 bypass
- SAI removed with forge motorsport blanking plate
- N112's removed
- Silicone turbo intake pipe
Transmission:
- Re-surfaced G60 flywheel (fitted at 75756 miles)
- Organic VR6 clutch with uprated clutch cover (30% more clamping force)
- All new bolts purchased from VW for conversion
Braking:
- 4 pot brembo brake upgrade (painted black with white porsche decals)
- Ferodo DS2500 pads
- AP brake fluid
Chassis:
- H&R cup suspension kit
- 5mm spacers at rear
Interior :
- Half leather
- Air con
- Nomad pillar with autometer boost gauge
- Ibiza cupra R gauge holder with autometer oil temperature and volt gauges
Wheels :
- Powder coated last month in dark anthracite
- 7 x 17 Mille Miglia (2 different offsets to clear brembo brakes)
- New centre caps, Spigot rings and wheel nut covers)
- Toyo proxe T1Rs 205/40/17
Audio :
- 0g wiring
- Alpine headunit with motorised screen
- Boot build
- DVD player (with remote control)
- Alpine 6 disc changer
- Alpine distribution block
- Alpine component speakers powered by a large un-branded amp
- JL audio sub (12'' in custom fibreglass boot build)
- JL sub powering amp
The mileage is just over 78000
Car will come with 12 months MOT and 6 months tax for the new owner. I will also do an oil and filter change prior to the sale.
I'm at work at the moment but i have lots to add. The car has recently had: New lambda sensors, Clutch and flywheel upgrade, MAF, coilpacks and a secondary water pump. No expense has been spared. I have £000s worth of reciepts, all MOTs all organised in a folder. Viewing is a must.
Car was rolling roaded recently and made 253bhp, this was prior to the G60/VR6 clutch upgrade, N249 bypass, SAI removal, N112 removal and silicone turbo intake pipe. So possibly a bit more than 253bhp.
More pics and info will be added later
£5750 ono
Mitch
Edited by Mitch_78GT
  • Views 364
