Gearbox Failure
My gearbox went this week on my 6n2
Getting it rebuilt tuesday, costing my £500 :-(
  • Replies 43
  • Views 3k
Mine went last month. I blame how low the car was and the fact the inner wings were resting on the driveshafts so there was no suspension :lol:
yeh whoever designs the gearboxes at vw should get the boot and make brevilles or something . . frickin pathetic
blew a mk3 8p box, 90k ish miles
spectacularly blew it
does the release bearing whine? i have this but it does not get louder as i accelerate? or when coasting. will a new clutch sort it? as i'm hoping its not gearbox related!
ha ha . . . spectacularly :lol:
mines gone thru 3 gearboxes
anyone had a GT gearbox go on them? also, does anyone else's GT gearbox crunch badly when you put it into reverse?
getting back on topic. my mates mk5 1.6fsi golf has just had to have its gearbox changed under warranty at ~48k so is it generally the newer stuff thats poo?
i think so mate, don't make them like they used to....
just about to change to my third DXJ gearbox. :sad:
Just had a £500 repair Job on my MK5 GTI gearbox.
It whirs a bit and reverse sometimes isn't totally in the mood, but 22 years on, Caligulas still works fine.
Just had a £680 full recon done on my mk5 gti. It had been whining for about 18 months, grinding the last two or three, and spectacularly screeching, scraping and crunching the last week. :-( Get it back Friday
Never had it happen to any the Polo's i've had but
it did happen to two Scirocco's and a Golf that i had.
To stop Reverse Crunch you put it in 1st then in to reverse :)
That is usually the Clutch Release Bearing, i had it on mine needed a new clutch and had a new gearbox while i was there :)
my box is grinding something cronic but doesnt do it AS MUCH when the clutch is depressed, apparently its my thrust bearing...bad times and lots of expense :(
Jon
Clutch release bearing only functions when the clutch pedal is depressed (not in a prozac way either) The noise should change with engine speed.
