1,6 8v AFT Timing question
Hi there:)
Pardon my English, not my native language :?
I have a 1,6 8v AFT engine that needed a new distributer, so i swapped in a new one, but i messed up the timing.
Been trying to find the TDC, top dead center so that i can install the distributer correctly, but i kinda confused about the timing marks.
Haven`t touched the timing belt, just turned the engine to see, but none the wiser :cry:
This is a picture of the camshaft wheel, the only mark i can find is a dot ingraved, circled in red at the right.
The cambelt cover has a mark, O.T, circled on the left.
On the crank i find these marks:
Another O.T mark on the right, on the distributer axle i believe?
And on crank sprocket there is only another dot, seen on the left.
Does anyone have schematics etc. that shows how this is supposed to line up?
The Haynes manual doesn`t tell much about this engine at all :cry:
  • Views 635
