6N Rally Polo
I'm only using 4-point harnesses, so front harness points is using one of the original seatbelt anchor points, the other we welded a mounting plate into the exhaust tunnel in the floor just behind the handbrake rear mounting point. Not sure where you'd put the 5th or 6th points for 5/6 point harnesses, probably makes sense to mount them to the seat mounting struts
  • Replies 154
  • Views 35.3k
Oh - not much in the way of updates because I'm getting married next year :D
limited to two events this year, the last one was in February and I did this:
After de-mudding the car....
Next one's in four weeks time, absolutely stoked - we won an award on the event last year, hoping to improve my result this year!
Can you upload a picture of how you have anchored the frontones for me? would be a great help!
Nice perfect wheel, no curbing or damage, one gently old lady owner! haha nicee chunk fella must have been going for platinum let alone gold haha! Love how the tyres still up tho!
  • 5 weeks later...
About time this was due a small update...
There's some plans in the pipeline for some mild upgrade - after numerous rear brake fade issues, I'm replacing the back axle with a disc axle conversion (free!) once I've got a replacement for the compensator
Went for another road rally last weekend (3rd/4th dec) and the car was going well, up until the thermostat housing exploded
Just for tech-ho, this is the best I can do for pics of the harness mounts:
I'd have to take the seats out to get a better picture, but the inner mounts (behind the handbrake) are drilled through, then the mounting plates are welded into the tunnel at that point (using some easy to get hold of harness mount plates from grayson - try rally-design or demon-tweeks)
  • 4 months later...
Great job with 6n :thumbsup: Could you post pics of the boot space? How did you organised/mounted carlift (jack?)/sparewheel etc. ?
