Speaker Sizes
As many people are asking for the speaker sizes in there 6n and others
- Front Door Components
The front door components are 6.5inch or 17cm in size and can be taken out by removing the door card. To remove the door card you will need to just pull at the door card from underneeth and unclip it, then it should just pull out.
To take the door component speakers out, you'll need to unscrew the screws which are holding the front speakers in.
- Dash Tweeters
The dash tweeters are 10cm in size and can be taken out by getting a screwdriver and levering the tweeter grill surround off, then just lever the tweeters out.
Hope this quick guide helps
Thank you
Mike
Edited by Mike1990
