G3URO G40 turbo
that is what I'm talking about!!!!!!!!!!!!!!!!!!!
So VW know that its a potential weak spot. be interesting to see if you can still get those panels!
  • Replies 679
  • Views 88k
yes , confirms your theory :-D , there are 3 known golfs with them fitted :shock: , vw panel though , apparently sold in countries with harsher road conditions , South Africa being one
So what have you actually done there? Welded in a section of steel?
No I believe its plywood max :lol:
I was more interested in its size and geometry, not material :lol:
I've just braced what i removed. its a stitched in piece of 20mmx250ish mm and its 4mm thick. the results speak for themselves - no flex between the piece i removed
very interesting indeed.
so will you have to brace the other side now, to keep the car drivable?
i did rhe exact same thing on the other side- so it has been fixed in the same way. it was only an issue because of the way i supported the car whilst i did some work. the passenger side was uneffected and i was able to fit the removed piece (+ cutting blade gap) back how it was- the drivers side had a 1mm difference and i then realised i could flex the whole leg up and down until i welded the piece back in- the strengthening plate is more to add peace of mind about the chassis leg flexing under load - esspecially seeing as its a Turbo G40
Lol , i was reading a thread over on clubgti today , seems VW offered a similar kit for the MK1 Golf back in the day ..
Fountain of knowledge as per usual mark, may have to do some thing along these lines myself when I swap my wings
VW blates designed those with mad max in mind, they look like they should be for guns :lol:
teaser
i think whats prompted me to do this is how others are catching up, i think this will put a full stop on my engine bay now. il post more up as she gets finished next week.
haven't decided what colour yet - was just gunna open a swatch and randomly stop and hope it wasnt pink
Hmmm don't know if I like the look of that, but I suppose it is still covered in filler.
thats just a skim, will be virtually filler free once its flat. and its all metal;-)
Been inspecting this today, looking good Kiz 8-)
i now want a mk3 just for a set of those rear lights. lol where they from ?
i bought them off this forum 4 years ago for £25, its one of the most asked questions about the car- and one i know the least about- i dont know who makes them or where to get them from hahahaha
http://www.ebay.co.uk/itm/FK-Automotive-Vo...8#ht_500wt_1054
Edited by woolley456
Chloes undertaken quite a transformation in the engine bay - heres a teaser before shes painted.
Chloe2007
Chloe2012
KiZ
Edited by youngprodigys
Do are u running no heater ect? Where do all the wires rct actually go through to the interior?
Looks great, wanna see it painted!
yes it runs a TT heaterbox located inside the cabin.
The wiring is all done by magic!
ah fair play son! hope i get to see this this year!
winning!
didnt go for the bracing bars then :ninja:
nah, thought it would be to much ober the top. i did seriously consider it however. still got a bit to do before I'm ready- GTI fest is looking unlikely as I've got to get a MOT in and have a good test drive before. I've put some long hours into this recently!
got your coilovers on yet?
Looking good. Looking forward to seeing this new colour
Looks good Kiz- you made the slam panel removable?
yer - made it removable, makes it so much easier to work on. plus is made getting the engine out a 30minute job for me and guy. 2 additional bolts on the wing each side, the headlight surround metal was cut and tacked onto the inner wing - and the vertical piece now has a bolt each side next to the headlight.
UPDATE
bay is now in primer:-) painting will happen hopefully saturday if i pull my finger out.
and a few shoots of my new pedals
need to ignore the dust everywhere! i have been sanding like hell for the above!
